07-05-2005, 12:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | Unlock NEC E338 Solution . And Unlocking E338 completed . But when i insert SIM card then show network . But only call emrgycall help 112 . I thinhk is set code to Unlock network. What is code Unlock to use network and SIM card. Best & Regards. |
07-06-2005, 07:26 | #3 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Depend of SW version. if <04 then you can easy unlock by any free or cracked sofrware ... of 04 you can only unlock with IMEI corruption. |
07-06-2005, 09:13 | #4 (permalink) |
Member: 135671 Status: Offline Thanks Meter: 45 | Thank all, But i thinhk is correct is Code is Unlock signal network, If is true code can Unlock it success. Because i can show Version software and IMEI. I have completed repair IMEI . And success Unlock it by Crassy . And caculate IMEI result code to Unlock but can not. Best & regrads |
nec e338 charge solution | samirov-gsm | NEC | 0 | 03-17-2009 11:31 |
Unlock NEC e338 with a USB cable? | laxxe | NEC | 11 | 09-30-2006 04:22 |
can furious unlock nec e338? | sonetek | FuriouS II | 3 | 12-06-2005 18:35 |
NEC E338 Working unlock solution? | ARC | NEC | 5 | 09-10-2005 11:36 |
IF someone CAN unlock LG U8130, U8138, NEC e338 plase post here | x_gsm | LG | 2 | 11-08-2004 09:02 |
