Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 09-27-2006, 20:45   #1 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
Unlock NEC e338 with a USB cable?
Hi!
Is it possible to unlock NEC e338 with a USB cable? I can only find solutions for COM cables (I have Crazzy dongle).
Old 09-28-2006, 22:55   #2 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
No reply yet - can't anybody help me?
Old 09-28-2006, 23:37   #3 (permalink)
KARIM GSM-ZONE's Avatar
Member: 74415
Sonork: gsm.zone
Thanks Meter: 314
yes you can just search brother
regards
gsm-zone
Old 09-28-2006, 23:39   #4 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
I've already tried to search (of course), but I haven't found anything usefull.
Old 09-29-2006, 00:50   #5 (permalink)
Jamal's Avatar
Member: 2845
Thanks Meter: 9
well make sure to install your driver for nec e338 first after make sure to use a usb cable the same as NEC E616, make sure to install the drivers first after to see that ur drivers installed go to control panel and u will see it from there click on port n u will see port number!!
what software are u using to unlock your e338?
good luck
Old 09-29-2006, 00:53   #6 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
I'm not using any software (yet) - since I'm looking for it! :-)
Old 09-29-2006, 01:28   #7 (permalink)
Jamal's Avatar
Member: 2845
Thanks Meter: 9
well if ur nec version 04 u need to download that to v3 and that an other story my friend ..If u only have one phone the best way just take it to a phone shop to unlock it for u cause Nec e338 not that easy ..Anyway there's few free softwares but u need a workign cable etc..
Old 09-29-2006, 12:54   #8 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
Hehe, simlock.dk is the largest/olderst unlock company in Denmark - but we don't have alot of NEC e338 phones in Denmark.
I needed some new equipment, and at the same time just ordered a clip, that should be able to unlock all versions of NEC e338.
Old 09-30-2006, 01:12   #9 (permalink)
Jamal's Avatar
Member: 2845
Thanks Meter: 9
to let u know some clips, are not good it change Imei for example to 0044 etc.. and not sure if that clip will support version 04 anyway if u want to send em the phone I will do it for u for free only ..You need to pay for the postage m8 ..I have all software for Nec but sometimes not easy to do v04 e338!
Old 09-30-2006, 01:23   #10 (permalink)
irishclips's Avatar
Member: 84155
Thanks Meter: 8
I can supply you server credit if you need. It will also unlock version 4 with no need to downgrade
Old 09-30-2006, 01:24   #11 (permalink)
Jamal's Avatar
Member: 2845
Thanks Meter: 9
ok help him to solve his problem of free ok n good bless u m8
Old 09-30-2006, 05:22   #12 (permalink)
Member: 173679
Thanks Meter: 9
use tool unlock Nec 3G and cable Rj45 Gx30 or usb cable . tested many phone
Unlock Nec e616 only have usb cable skalman66 NEC 5 02-18-2008 08:08
can furious unlock nec e338? sonetek FuriouS II 3 12-06-2005 18:35
unlock NEC e606 with test point cable? Muneer Ahmed NEC 21 08-13-2005 01:24
Unlock NEC E338 Solution . nctrung_vn NEC 4 07-06-2005 13:56
Page generated in 0.46241 seconds with 8 queries
