06-19-2015, 11:48 | #16 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | for your help, Code: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM176 Connecting; Init; Port opened; Phone detected (@oem151.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM77 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706136901-9 PTH: 10 PTS: W5B PROV_ID: V895N-2GVDNZ2 SBTADDR: D0:9D:AB:74:6E:CA SWIFIADDR: D0:9D:AB:74:6E:CB HS_PN: SAA6197AAS0C SSN: 3PKC33CBFIY03RY Work id: 0ACBBD65 Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W5FJB1BG00 Size: 00000430 Backup saved to: 35690706136901-9 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_19_06_2015_23_40_40.txt Time needed - 00:00:29 |
06-19-2015, 12:59 | #17 (permalink) |
Freak Poster Join Date: Jun 2007 Location: United Kingdom
Member: 533083 Status: Offline Thanks Meter: 76 | Vodafone vf-895n succefully unlocked HERE IS THE LOG Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (USB Composite Device) Preparing to enter download mode; Preparing to open COM31 Connecting; Init; Port opened; Phone detected (Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM35 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706145867-1 PTH: 10 PTS: W5B PROV_ID: V895N-2GVDPT1 SBTADDR: 3C:CB:7C:E9:48:7D SWIFIADDR: 3C:CB:7C:E9:48:7E HS_PN: SAA6197AAS0C SSN: 3PKC33CBEHY02DX Work id: 0A97ABAE Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W5FFB0BG00 Size: 00000430 Backup saved to: 35690706145867-1 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_19_06_2015_12_56_52.txt Time needed - 00:00:38 Connect the powered off phone..wait until it shows the battery icon. then install drivers for the ports..open amdo (pack5) ..check firehorse mode and click on do job. no need to root the phone. |
The Following User Says Thank You to abdullahkhank For This Useful Post: |
07-29-2015, 12:32 | #21 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | VODAFONE SMART PRIME 6 Unlock Done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM158 Connecting; Init; Port opened; Phone detected (@oem154.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM160 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706116227-3 PTH: 10 PTS: W5C PROV_ID: V895N-2GVDGB2 SBTADDR: 3C:CB:7C:B3:8D:00 SWIFIADDR: 3C:CB:7C:B3:8D:01 HS_PN: SAA6197AAS0C SSN: 3PKC33CBFHY01PL Work id: 0A9032F7 Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W5FCJ3BG00 Size: 00000430 Backup saved to: 35690706116227-3 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_29_07_2015_17_30_12.txt Time needed - 00:00:23 |
The Following User Says Thank You to kushol For This Useful Post: |
08-12-2015, 20:23 | #22 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | cant connect on Vodafone vf-895n new.Vodafone smart 6,Android .5.0.2.baseband 8939AAAAANLYD2035A.1,bUILD NUMBER LR22 RELEASE-KEY,Custom build version:060fgn1.Am using windows 7 ultimate . Qcom smart tool version 1.0.09686 |
08-13-2015, 08:10 | #23 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Watch the video to see how to connect it. Br | |
08-26-2015, 19:08 | #24 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Accra-Ghana
Member: 1412214 Status: Offline Thanks Meter: 6 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM188 Connecting; Init; Port opened; Phone detected (@oem389.inf,%devicedesc.zeus%;ZEUS Flash Device) Preparing to start flash mode; Log file saved to: LOG_26_08_2015_18_06_40.txt Time needed - 00:00:06 |
08-30-2015, 19:22 | #25 (permalink) | |
You have wrong drivers installed (sony ericsson ones .. @oem389.inf,%devicedesc.zeus%;ZEUS Flash Device) . Go device manager once the error occurs and install the alcatel ones Br | |
10-10-2015, 12:38 | #26 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 54
Member: 166398 Status: Offline Thanks Meter: 21 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Périphérique USB composite) Preparing to enter download mode; Preparing to open COM90 Connecting; Init; Port opened; Phone detected (@oem166.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM45 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706511485-8 PTH: 13 PTS: W5J PROV_ID: V895N-2GVDGB2 SBTADDR: 8C:99:E6:26:51:37 SWIFIADDR: 8C:99:E6:26:51:38 HS_PN: SAA6197AAS0C SSN: 3PKC34CFELY047R Work id: 0B8CAF95 Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W5FCJ3BG00 Size: 00000430 Backup saved to: 35690706511485-8 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_10_10_2015_12_36_03.txt Time needed - 00:00:29 |
The Following User Says Thank You to chliki2001 For This Useful Post: |
