01-11-2015, 17:12 | #31 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | AT&T ZTE F555 unlock done Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : May 10 2013 15:02:00 RELEASE DATE : Nov 8 2012 03:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 86481801288769-1 BLUETOOTH ADDR : B0 5B 2D 1D F3 30 FIRMWARE: ATT_US_P752A15V1.0.0B17 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; PERFORMING EXTENDED UNLOCK; SIM_LOCK REMOVED ! RESET ! |
01-11-2015, 17:15 | #32 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | AT&T Z432 unlock done Software engine version: 1.0.0.9021 Searching phone ... MODEL : QCOM SERIES 26 COMPILED DATE : Jun 17 2014 00:42:00 RELEASE DATE : Feb 2 2012 18:00:00 FIRMWARE INFO : ATT_AM_Z432V2.0.9B01-S IMEI : 86348702301071-8 BLUETOOTH ADDR : BF 2B CB F5 6C 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 1C4C360054E912D4BD915AB9720DE705.bin ERASING; WRITING; READING; AFTER BACKUP: 9940618501B76199EAD0B55B55077CE4.bin UNLOCKED; RESET ! |
01-16-2015, 20:04 | #34 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SkypePhone WP-S2 unlock done Software engine version: 1.0.0.9082 Searching phone ... MODEL : QCOM SERIES 2 [KYUZ] COMPILED DATE : Apr 10 2009 19:16:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 35422202266656-6 BLUETOOTH ADDR : 0F E1 54 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! |
The Following User Says Thank You to shainelus For This Useful Post: |
02-02-2015, 15:50 | #35 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Huawei G6-L11 unlock problem Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; Uploading data; BRAND: HUAWEI MODEL: HUAWEI G6-L11 ANDROID: v4.3 CPU: QCOM IMEI: 864037021536583 KERNEL: Linux version 3.4.0-g0544bc5 (@pekeaulxd0011) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Oct 30 15:15:17 CST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; ERROR: Backing up Failed ! |
02-02-2015, 16:46 | #36 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 42
Member: 63646 Status: Offline Sonork: 1670920:45069 Thanks Meter: 23 | I have the same problem, always getting this report, Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; Uploading data; BRAND: HUAWEI MODEL: HUAWEI G6-L11 ANDROID: v4.3 CPU: QCOM IMEI: *************** KERNEL: Linux version 3.4.0-ga5da9d0 (@pekeaulxd0006) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Jul 3 21:07:51 CST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; ERROR: Backing up Failed ! Log file saved to: LOG_2_02_2015_16_16_59.txt Time needed - 00:01:25 |
02-03-2015, 10:13 | #37 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Because the exploit fails on your phone. Try downgrading the firmware Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
02-03-2015, 11:01 | #38 (permalink) | |
I had on my phone flashed G6-L11 V100R001HWC00B107_Firmware_Germany_Android 4.3_EMUI 2.0_05012FXS.zip or G6-L11 V100R001C00B127_Firmware_general_Android 4.3_EMUI 2.0 Lite_05012BPE.zip Br | |
02-03-2015, 13:16 | #39 (permalink) |
Member: 7557 Status: Offline Thanks Meter: 26 | Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; Uploading data; BRAND: HUAWEI MODEL: HUAWEI G6-L11 ANDROID: v4.3 CPU: QCOM IMEI: 864037021536583 KERNEL: Linux version 3.4.0-g7f1569d (@pekeaulxd0017) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Jul 21 13:23:58 CST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00160720 bytes Decompressing; Backup saved to: 864037021536583 Finished; IMEI: 864037021536583 BT ADDR: 9C:C1:72:45:2E:9D MAC ADDR: 9C:C1:72:45:39:13 BOOTLOADER PASS: 1732411779863191 MCC-MNC: [vodafone/default] LOCK [0] HASH: 16F9103A11CF709E18561879FFC3BB6F LOCK [1] HASH: 1C0AFB1AA74C2CA1AB7E61CCCAAF6EC1 LOCK [2] HASH: FD62A5A438C1C126DD7439170BD0368E LOCK [3] HASH: 9E94477CB60D8F8ACA013EBAE18D7486 LOCK [4] HASH: 9E94477CB60D8F8ACA013EBAE18D7486 LOCK [5] HASH: FAF46CD0E17990EB3F3899ECFFCC9E12 LOCK [6] HASH: 701A00D305075415B45464AECB7BC3E3 LOCK [7] HASH: 9E94477CB60D8F8ACA013EBAE18D7486 LOCK [8] HASH: 9E94477CB60D8F8ACA013EBAE18D7486 LOCK [9] HASH: 9E94477CB60D8F8ACA013EBAE18D7486 Starting; Done; Unlocking in progress; Calc 0000 ; Calc 0001 ; SIM_LOCK REMOVED ! Rebooting; Have change the firmware and all good now Thanks Daniel |
02-03-2015, 14:22 | #40 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Added to the support G6-L11 V100R001HWC00B107_Firmware_Germany_Android 4.3_EMUI 2.0_05012FXS.zip G6-L11 V100R001C00B127_Firmware_general_Android 4.3_EMUI 2.0 Lite_05012BPE.zip G6-L11 V100R001C02B116_Firmware_Germany_Italy_Portugal_Sp ain_android 4.3_EMUI 2.0_05012GHP.zip Update the phone using these firmwares if you get the bellow error while unlocking G6-L11 Code: Exploiting; Android v4.3 TRUE Backing up sec area; ERROR: Backing up Failed ! Br |
02-03-2015, 19:20 | #41 (permalink) | |
Member: 63646 Status: Offline Sonork: 1670920:45069 Thanks Meter: 23 | Quote:
Original you phone was TIM ? , what is the firmware you flashed in it ? | |
02-04-2015, 18:23 | #43 (permalink) |
Junior Member Join Date: May 2009 Location: Bucuresti
Member: 1039386 Status: Offline Thanks Meter: 1 | Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; Uploading data; BRAND: ORANGE MODEL: ORANGE GOVA ANDROID: v4.3 CPU: QCOM IMEI: 864045021109913 KERNEL: Linux version 3.4.0-g3d8f971 (j71036@mha-Tecal-XH620) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 17:47:30 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00192857 bytes Decompressing; Backup saved to: 864045021109913 Finished; IMEI: 864045021109913 BT ADDR: 9C:C1:72:C3:4E:63 MAC ADDR: 9C:C1:72:C3:52:60 BOOTLOADER PASS: 6219916915899515 MCC-MNC: 226-10 [orange/ro] LOCK [0] HASH: CABB8511113A1E772ED9E29C5B5A4B84 LOCK [1] HASH: 4BA4229F47E6FC12BA62311B763C5075 LOCK [2] HASH: 41DAB366CA43331DB0846FDC5E4FE7EB LOCK [3] HASH: 6B6C6013991C6CCFB5F461BC97E27C65 LOCK [4] HASH: 6B6C6013991C6CCFB5F461BC97E27C65 LOCK [5] HASH: 540752E7AC753056DB032392813D400F LOCK [6] HASH: 61F2590D356DD7C4AF54FBB1347AAB13 LOCK [7] HASH: 6B6C6013991C6CCFB5F461BC97E27C65 LOCK [8] HASH: 6B6C6013991C6CCFB5F461BC97E27C65 LOCK [9] HASH: 6B6C6013991C6CCFB5F461BC97E27C65 Starting; Done; Unlocking in progress; Calc 0000 ; SIM_LOCK REMOVED ! Rebooting; |
The Following User Says Thank You to geoman86 For This Useful Post: |
02-05-2015, 02:18 | #45 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Slovakia VT
Member: 59529 Status: Offline Thanks Meter: 115 | Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; Uploading data; BRAND: HUAWEI MODEL: HUAWEI G6-L11 ANDROID: v4.3 CPU: QCOM IMEI: 864037020921893 KERNEL: Linux version 3.4.0-g7f1569d (@pekeaulxd0017) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Jul 21 13:23:58 CST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00178930 bytes Decompressing; Backup saved to: 864037020921893 Finished; IMEI: 864037020921893 BT ADDR: CC:A2:23:37:7F:01 MAC ADDR: CC:A2:23:37:8A:BA BOOTLOADER PASS: 1332231931211112 MCC-MNC: [sfr/fr] LOCK [0] HASH: E0DD19DA205F17250768C0442F47674B LOCK [1] HASH: 8477328226BD049DEA4050D8316A6A28 LOCK [2] HASH: 3DAA9A9B2E981C520F53B53C57C32FDC LOCK [3] HASH: 1F793F03FD61AF74D8BB62A8E03073BE LOCK [4] HASH: 1F793F03FD61AF74D8BB62A8E03073BE LOCK [5] HASH: 12FFCF5A8459E8F4C3D28FB7264AFB6E LOCK [6] HASH: A22454A6F41CF392A996E7318B74D1FA LOCK [7] HASH: 1F793F03FD61AF74D8BB62A8E03073BE LOCK [8] HASH: 1F793F03FD61AF74D8BB62A8E03073BE LOCK [9] HASH: 1F793F03FD61AF74D8BB62A8E03073BE Starting; Done; Unlocking in progress; Calc 0000 ; Calc 0001 ; SIM_LOCK REMOVED ! Rebooting; Log file saved to: LOG_5_02_2015_02_17_25.txt Time needed - 00:01:14 |
