04-02-2015, 16:25 | #16 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | |
04-02-2015, 19:54 | #17 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Should work on all. Be sure is not some issue created by your antivirus. Br | |
04-08-2015, 10:09 | #19 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | ADDED AVVIO_295_Bmobile_EN_PATCHED-2.spd -> WORLD FIRST SPDTooL_v1.0.0.2002.rar -> AVVIO 295 SUPPORT |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
05-09-2015, 11:28 | #20 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | HTC 310 UNLOCK DONE! Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem14.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM154 Connecting; Downloading DA; Initializing; Rid: f6c7174f6d0ea00bbcc86e90a3725de2 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem14.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM155; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA1030504 0xCD21E866 [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x62000000 SIZE: 0x87C00000 Searching data; Locked to [SIM1]: 505-03 code_cat_n: 10082864 enabled: yes tries: 11 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Locked to [SIM2]: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:28 |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
05-12-2015, 16:49 | #21 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi supporters.. i m getting error while changing cid.. but there is no pb on unlocking or another options.. Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem133.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: 673760e9263fea0b9ff0c42193de89b6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem133.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM54; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA1020504 0x69410DC7 [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x62000000 SIZE: 0x87C00000 Searching data; Checking data; Reading data failed; Time needed - 00:00:07 |
05-13-2015, 08:06 | #22 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
05-13-2015, 11:36 | #24 (permalink) | |
It's normal not to exist if the latest version is 1.0.0.834. And you ahev full install here http://www.mediafire.com/download/9a...l_27042015.exe | |
05-13-2015, 11:58 | #25 (permalink) | |
is there any bug on latest software..? what can be pb..? u have any idea..? | |
05-14-2015, 13:25 | #27 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | didnt u read my previos posts..? i have the change cid desire 310.. but not changing.. Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem133.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: 673760e9263fea0b9ff0c42193de89b6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem133.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM54; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA1020504 0x69410DC7 [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x62000000 SIZE: 0x87C00000 Searching data; Checking data; Reading data failed; Time needed - 00:00:07 |
05-15-2015, 08:51 | #28 (permalink) | |
Br | |
06-08-2015, 09:43 | #29 (permalink) |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start flash mode; ERROR: Device not found ! ERROR: BOOT_PHONE; |
