Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| FuriouS TeaM Products FuriouS GOLD Support Area |
| | #92 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005 Location: http://g s m links.110mb.com/
Member: 202333 Status: Offline Thanks: 33
| hi, its not direct unloc .... its read code Searching phone; Phone detected (@oem226.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM39); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P18 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-182188-6 Reading simlock info; Locked to: 208-01 code_cat_n: 18760743 enabled: yes tries: 0 code_cat_ns: 04966899 enabled: no tries: 10 code_cat_sp: 10523454 enabled: no tries: 10 code_cat_c: 14864632 enabled: no tries: 10 code_cat_sim: 24628065 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:16 my phone is still locked and counter blocked ... i try soft reset and hard reset and still same .... any suggest ? |
| | #94 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: some were in my head Age: 31
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks: 85
| i repeat again not suport ot 232 and ot 217 good cable but not work i try to read the cpu information evice: _Autodetect MT6205-6239 NOR Initialization done Device: _Autodetect MT6253 NOR Action: read/check information Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6251, E03 Hardware version: JRDHZ51_11A_HW Software version: MAUI.11A.W11.12.MP.V Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 865008013448920 but with furious no can read cpu ... |
| | #95 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks: 388
| Quote:
THis log is not from our soft and i dont see the point of pasting it here. As long the cable is ok it will be detected by mtkreader too Br | |
| | #96 (permalink) |
| i am on line now with one pc of ot 232 this the log with your soft check it COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
