Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-08-2018, 10:55   #1 (permalink)
Member: 2501288
Thanks Meter: 202
Unhappy 8050d dead after flash [SOLVED]
8050d dead after flash with 8050D-2[X=A,B,C]ALAP1.
i have also 8050D-2[X=A,B,C,D]VDGH4 but not revive it
Using library Brom_DLL_v7.1813.3
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6))
Preparing to start flash mode;
Preparing to open COM6
Connecting;
Downloading DA;
Initializing;
Rid: 6b07e652f155b2e7d929768cbc208b03
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6580 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xC8B30142 0x057483D2 [SIZE=0x1D2880000]
IMEI1 [OTP 0001]: 354124-08-731090-0
IMEI2 [OTP 0001]: 354124-08-731091-8
PROVIDER: 8050D-2GALWEL-1
USRDATA INFO: 0xB9800000 SIZE: 0x114C80000
Loading the file ...
Cfg done ...
Formatting file system now...
Done;
Formatting SECCFG partition now...
Done;
Formatting FRP partition now...
Done;
Formatting NVDATA partition now...
Done;
Formatting METADATA partition now...
Done;
Downloading bootloader...
Done;
Downloading images...
Done;
Success;
Time needed - 00:04:49
Old 11-08-2018, 11:42   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 52,237
Must download 8050D-2[X=G]ALWEL-1_1ACXL5X1.osp from support and flash that !
Old 11-08-2018, 11:48   #3 (permalink)
Member: 2501288
Thanks Meter: 202
The problem my support expired
Old 11-08-2018, 12:45   #4 (permalink)
Member: 15022
Sonork: 100.53452
Take from https://mega.nz/#!lDRxTITa!eJaZpplMQ...RyiBbz4A5mJ1e4
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post:
Old 11-08-2018, 21:32   #5 (permalink)
Member: 2501288
Thanks Meter: 202
this phone make me crazy
when i select YES, only detected with holding volume UP
Searching phone in emergency mode;
[connect the phone powered off with volume down pressed to the usb cable]
Phone detected (MTK USB Port (COM132))
Preparing to open COM132
ERROR: Comport open failed !
ERROR: BOOT_PHONE;
Old 11-09-2018, 09:10   #6 (permalink)
Member: 15022
Sonork: 100.53452
before pressing yes you must remove usb cable and battery and reattach when the sw is starts searching for it ! it write clearly in teh mmessage box and you didnt do that !
Old 11-09-2018, 09:29   #7 (permalink)
Member: 2501288
Thanks Meter: 202
That's what I do exactly, i repaire same situations like this before, but this i dont knows where's the problem , note that the phone was working good just has problem with WhatsApp recorder!
I see the comport still busy from the first connect , any way to flash in emergency mode in the first time directly without the message YES or NO
Old 11-09-2018, 12:23   #8 (permalink)
Member: 2501288
Thanks Meter: 202
i think the problem is software not déconnect from comport after the first operation
Old 11-09-2018, 19:18   #9 (permalink)
Member: 2501288
Thanks Meter: 202
i have this error with old version
Connecting;
Downloading DA;
Initializing;
Done;
USB SPEED: USB_FULL_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem148.inf,%mtk_sp_da%;DA USB VCOM Port)
TRYING TO OPEN COM7;
DEVICE INFO:
BB CHIP: MT6580_S00 [CA00, 00, 6580, 05]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
USRDATA INFO: 0xB9800000 SIZE: 0x19080000
ERROR: S_NOT_ENOUGH_MEMORY
Time needed - 00:00:24
Old 11-11-2018, 20:39   #10 (permalink)
Member: 2501288
Thanks Meter: 202
Waiting any advice to revive this set pleas
Old 11-12-2018, 08:13   #11 (permalink)
Member: 15022
Sonork: 100.53452
I told you after pressinng YES you must deattach the usb cable and reattach tablet batterry and after when the sw start looking for it connect it to the usb with volume down pressed ! Contact me on skype if you dont manage !
Old 11-12-2018, 08:59   #12 (permalink)
Member: 2501288
Thanks Meter: 202
Yes that's what i do, the new software make the port busy from the first connect even when i disconnect usb and battery ! Any way i will contact you today to see the problem exactly
Thank you
Old 11-12-2018, 11:03   #13 (permalink)
Member: 15022
Sonork: 100.53452
Ok im waiting for you
Old 11-12-2018, 11:58   #14 (permalink)
Member: 2501288
Thanks Meter: 202
problem solved remotly with .:hack3r2k:.
Now phone revived, after many tools fail
Connecting;
Downloading DA;
Initializing;
Done;
DEVICE INFO:
BB CHIP: MT6580 [CA00, 00, 6580, 05]
Cfg done ...
Done;
Done;
Done;
Done;
Done;
Done;
Done;
Success;
Time needed - 00:04:37
The Following User Says Thank You to Steve-1 For This Useful Post:
Page generated in 0.16647 seconds with 7 queries
