09-23-2016, 23:29 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Age: 37
Member: 520810 Status: Offline Thanks Meter: 231 | i am sorry model is 5054 flint cricket Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Dispositivo compuesto USB) Preparing to enter download mode; Preparing to open COM474 Connecting; Init; Port opened; Phone detected (@oem362.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM486 Connecting; Loading; Init; Port opened; Hello Received; ERROR: Boot loading failed; Log file saved to: LOG_23_09_2016_18_28_31.txt Time needed - 00:00:13 |
09-27-2016, 08:06 | #5 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | |
09-28-2016, 18:04 | #6 (permalink) |
Member: 520810 Status: Offline Thanks Meter: 231 | Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: TCL MODEL: ALCATEL_5054O ANDROID: v5.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-g6e268a6 (android-bld@bld71) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Feb 4 00:19:54 CST 2016 Cleaning; Loading files; Done; Reconnecting; Getting memory info; Done; Gathering info; Done; Cleaning done; Setting permissions; Reading data; Getting data size; 00001241 bytes Decompressing; IMEI: 0145560009xxxxx PTH: 13 PTS: GAF PROV_ID: 5054O-2KRKUS3-R SBTADDR: F0:34:04:41:B3:81 SWIFIADDR: F0:34:04:41:B3:82 HS_PN: SAA35HPAA10C SSN: F1KG07CNBGZ02ZC Getting data size; 00505557 bytes Decompressing; Mounting the partition; Done; WARNING: Lower then; Done; Done; Getting data size; 00001791 bytes Decompressing; Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 04577536 Calculating security; Calc 0000 ; Calc 0001 ; Calc 0002 ; Calc 0003 ; SIM_LOCK REMOVED ! Log file saved to: LOG_28_09_2016_12_57_37.txt Time needed - 00:02:09 |
The Following User Says Thank You to urecel For This Useful Post: |
