07-18-2019, 23:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | after repairing the imie does not change follows the same imie [SOLVED] Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM32)) Preparing to start flash mode; Preparing to open COM32 Connecting; Downloading DA; Initializing; Rid: 1946b5120560ecc9e44401150ebcc3bd Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x0DD40142 0xAD161FD3 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Searching data; Checking data; Contents saved to : D:\basura\boxz\furios\OTSmart_v1.0.0.3475_WhosYour Daddy_Edition\HUAWEI Y6 2019_IMEI_0AAD8B9A_5650EA15_1946b5120560ecc9e44401 150ebcc3bd_18_07_2019_17_40_28.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM31)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; IMEI repaired; Remove battery and cable; Time needed - 00:03:11 Log file saved to: LOG_18_07_2019_17_43_37.txt |
09-05-2019, 22:27 | #5 (permalink) |
Freak Poster Join Date: Aug 2011 Location: pretoria
Member: 1636627 Status: Offline Thanks Meter: 24 | New update has bug sir. I face same problem. After change imei phone only boot in recovery and after flashing with file from suport phone shows same imei. After flashing file if i try to change imei operation done successfully but imei not changed |
09-06-2019, 06:22 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Theres no bug since nothing changed and we tested on our handsets. After flashing you must configure phone and after must repair imei. It will work. If is not attach here the backup made and contact me over telegram or skype. | |
10-07-2019, 17:30 | #7 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | same does not change , completed but not successfull mrd-lx1 flashed with Madrid-L21A 9.0.1.184(C431E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1 is this correct thanks Last edited by kammy6000; 10-07-2019 at 17:36. |
10-08-2019, 18:08 | #9 (permalink) |
Member: 467279 Status: Offline Thanks Meter: 42 | still not work ? dont know factory reset done flashed Madrid-L21A 9.0.1.184(C431E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1 redone operation sucessfull but not change version too high? |
