02-24-2012, 12:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | alacatel ot 108 problem this is the log Make your handset power off, plug in the UART cable! Product: OT-108 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Start to rebuild security region... IMEI: 359908035861823 Rebuild security region failed! Error Code: 8029 Please double check the cable and handset connection! Try it again! Make your handset power off, plug in the UART cable! Product: OT-108 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Start to rebuild security region... IMEI: 359908035861823 Rebuild security region failed! |
02-24-2012, 13:50 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | I know this kind a long time but someone block search about it!!!!!!! I leave that discussion and know that Team don't do anything about(it's not Team fault)! By have many tools we don't mind!!!!!!All ot-108 are unlocked! |
02-24-2012, 15:30 | #3 (permalink) | |
No Life Poster Join Date: Jun 2010
Member: 1326910 Status: Offline Thanks Meter: 240 | Quote:
No one report the 8029 error for OT-108 before, so I don't add special operation for this model. But you can select OT-209 in product drop list with the OT-108 flash file in support, and try full image flash function to remove some special security config in memory of your OT-108 handset. Then do secure region rebuild or code unlock. B.R. Eason | |
03-02-2012, 13:40 | #7 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | is about ot 108 first time i try to unlock it by rebuild security say error 8029 after that i try to select ot 209 and full flash it with ot108 but begin the flash and after few time ask me to chek my cable connection |
03-02-2012, 13:42 | #8 (permalink) | |
"after that i try to select ot 209 and full flash it with ot108 but begin the flash and after few time ask me to chek my cable connection" Which error ID? Post log and check whether your test pin usage is correct. B.R. Eason | |
03-02-2012, 17:21 | #9 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | yo bro this is the log Make your handset power off, plug in the UART cable! Product: OT-209 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... Flash handset image failed! Error Code: 8102 Please double check the cable and handset connection! Try it again! |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
