05-30-2017, 11:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | Alcatel 1016G Unlocking problem I am having an issue to unlock Alcatel 10.16G. I have flashed with different firmware but the issue still remains. Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem106.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM6]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: NONE SW IMEI[1]: NONE SW IMEI[2]: NONE SW IMEI[3]: NONE SIMLOCK FLAG: OFF FIXED NV BASE: 303C0000 Reading NV; ERROR: NV partition is damaged ! Reflash the phone; Log file saved to: LOG_30_05_2017_11_06_46.txt Time needed - 00:00:16 |
05-30-2017, 23:20 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | You are using an old version. Get SPDTooL_v1.0.0.3026.rar Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
06-04-2017, 01:22 | #3 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | Thanks for the reply but still same issue log file. I am using latest software. Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem32.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM4]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: NONE SW IMEI[1]: NONE SW IMEI[2]: NONE SW IMEI[3]: NONE SIMLOCK FLAG: OFF FIXED NV BASE: 303C0000 Reading NV; ERROR: NV partition is damaged ! Reflash the phone; Log file saved to: LOG_4_06_2017_01_19_32.txt Time needed - 00:00:17 |
06-04-2017, 08:11 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Try selecting OT-1016 (1) Br | |
