12-11-2015, 00:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Croatia Age: 45
Member: 3508 Status: Offline Thanks Meter: 71 | Alcatel 2045X unlock problem [SOLVED] I have Alcatel 2045X and can't unlock it with OTZ Flasher v1.0.0.1595!? Should I try to flash it!?!? Here is log, I tried several times, always the same problem: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM12)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6276 Sw version: 2045X_L4GM_V1.4_150709_CAM30_MCP128_64_FM_BT_Y_CH_ SWISSCOM Hw Version: HW01 Reading phone info; IMEI: 355626-06-2xxxxx-x Reading; Reading security; ERROR: Reading failed; Please retry; Time needed - 00:00:24 Log file saved to: LOG_11_12_2015_00_21_29.txt BR |
12-11-2015, 00:56 | #2 (permalink) |
Member: 3508 Status: Offline Thanks Meter: 71 | SOLVED Alcatel 2045X unlock ...i found that it should be unlocked with MTK Code Reader v.1.0.0.608 and it works OK! Sorry for posting.... Here is LOG: Searching phone; Phone detected (MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 2045X_L4GM_V1.4_150709_CAM30_MCP128_64_FM_BT_Y_CH_ SWISSCOM Hw Version: HW01 Reading phone info; IMEI: 355626-06-2xxxxx-x Reading simlock info; Unlock codes: Locked to: 228-01 code_cat_n: 90169673 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:19 Log file saved to: LOG_11_12_2015_00_53_49.txt BR |
