03-31-2016, 22:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 41
Member: 99756 Status: Offline Thanks Meter: 32 | alcatel 3000h white screen after flash andcan't restore original dump [SOLVED] plz help i read a dump from working phone and try to flash it with files from support to change lang (i test all files ) from first one it make phone white screen and i try to restore original dump it give me wrong file version ?? the problem is in otz flasher cause i try to read dump again and restore it it give me the same wrong file vision i tried OTZFlasher_v1.0.0.1425 OTZFlasher_v1.0.0.1387 OTZFlasher_v1.0.0.1415 OTZFlasher_v1.0.0.1601 plz help |
04-01-2016, 09:48 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
04-02-2016, 16:18 | #4 (permalink) |
Member: 99756 Status: Offline Thanks Meter: 32 | here is my original dump when i load it to otz flasher it closed and give alot of errors and some virsions of otz flasher load the dump and give me when i flash error file virion http://www.filedropper.com/memorydump00400000 |
04-02-2016, 16:20 | #5 (permalink) |
04-03-2016, 10:33 | #6 (permalink) | |
Is normal to give error because dump write is not possible Get from the support and write 3000H-2[X=A,B,C]ALIN1.otz Br | |
04-03-2016, 14:41 | #7 (permalink) |
Member: 99756 Status: Offline Thanks Meter: 32 | I try all files in 3000h folder in the support all give white screen and you hear the phone works I tried to flash it with 3000d it work but only 2 Sims are work not the 3 Sims I wonder why it can't restore the original flash under the battery. 3000h ALIN1 what can I do ? |
04-04-2016, 08:19 | #8 (permalink) | |
man really. I told you to get again 3000H-2[X=A,B,C]ALIN1.otz. ITS A NEW FILE !!!!!!!!!!!!!!!!!!!! Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
