08-18-2016, 12:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Alger Age: 57
Member: 295459 Status: Offline Thanks Meter: 68 | alcatel 5022D error to flash Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: bc9af094ea05d3a1dbf44eb8bd25362f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM60; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x556F0042 0xE7B2BA9B [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5022D-2BALDZ1 USRDATA INFO: 0x97800000 SIZE: 0x3B080000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... programm\software\pack 06\OTSmart.exe this application has requested the Runtime to terminate it in an unusual way please contact the application's support team for more information Last edited by GSMTOPSUD; 08-18-2016 at 12:49. |
08-18-2016, 13:41 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Can be because of: 1. Not enough free empty space 2. Badly downloaded firmware (can try other and see if the error persists) 3. Some antivirus messing up process memory (can try to disable it if you have one) 4. Some **** from the protector Contact me over skype so i can check |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
08-20-2016, 12:17 | #3 (permalink) | |
Member: 295459 Status: Offline Thanks Meter: 68 | Quote:
problem is windows XP but with windows 7 Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM (Android) (COM85)) Preparing to start flash mode; Preparing to open COM85 Connecting; Downloading DA; Initializing; Rid: bc9af094ea05d3a1dbf44eb8bd25362f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem325.inf,%vcom_da%;DA USB VCOM (Android)) TRYING TO OPEN COM116; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x556F0042 0xE7B2BA9B [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5022D-2BALDZ1 USRDATA INFO: 0x97800000 SIZE: 0x3B080000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:01 Log file saved to: LOG_20_08_2016_11_56_39.txt | |
08-22-2016, 07:37 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
08-23-2016, 21:39 | #5 (permalink) |
Major Poster Join Date: Jun 2006 Location: greece
Member: 300055 Status: Offline Sonork: 100.1620508 Thanks Meter: 0 | 5022d alcatel not enough memory i have the same proble here. i try everything but the same .i have 32gb free space win 7 32bit.any other solution? |
09-05-2016, 12:04 | #7 (permalink) |
Crazy Poster Join Date: Jun 2005 Age: 39
Member: 152024 Status: Offline Thanks Meter: 7 | DA_HIGHSPEED_VCOM (@oem140.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM19; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x8FB20042 0x47B2256A [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5022D-2AALWE1-1 USRDATA INFO: 0x97800000 SIZE: 0x3B080000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:02 ot5022d flashing fail |
09-05-2016, 17:49 | #8 (permalink) | |
Not enough ram or hdd space Br | |
11-24-2016, 00:54 | #9 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | Under XP: (Free space 277GB rm 8gb but xp see 3gb) Win1064bit (Ram 8gb, ssd free space 64gb ) Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM88)) Preparing to start flash mode; Preparing to open COM88 Connecting; Downloading DA; Initializing; Rid: ad60fdba86968fccaac488b386d7f64c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem236.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM127; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x504E01FE 0x35394A31 0x2D8B124B 0xF363778F [SIZE=0x1D3600000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5022D-2AALWE1-1 USRDATA INFO: 0x97800000 SIZE: 0x3BE00000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:02 Log file saved to: LOG_24_11_2016_00_52_02.txt |
11-24-2016, 08:30 | #10 (permalink) | |
Br | |
