03-29-2016, 08:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | ALCATEL 5037X dead after flash [SOLVED] Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM24)) Preparing to start flash mode; Preparing to open COM24 Connecting; Downloading DA; Initializing; Rid: 183e2435dbcdff563afc070ab3023cee Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM17; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, 05] HW_STORAGE_EMMC: 0x30000111 0x39473430 0xDA8A1030 0x89417F84 [SIZE=0xEC480000] IMEI1 [OTP 0001]: 865470-02-165731-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5037X-2ADHMY1 USRDATA INFO: 0x5C6C0000 SIZE: 0x8FDC0000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:42 Log file saved to: LOG_29_03_2016_13_28_59.txt |
03-30-2016, 09:54 | #4 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | thx for the new file,set is started working with the new file, but its setting is not opening. on opening setting icon it gives this error (no application can perform this action process % is not responding) |
03-30-2016, 16:16 | #7 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
man the phone came stuck on logo to you so how can you tell this stupid thing like "WAS WORKING OK ". Any gadget works ok till gets damaged. And that is the original ALCATEL flash. It crashes because some hw fault Br | |
04-05-2016, 14:47 | #8 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | [QUOTE=.:hack3r2k:.;11726721]man the phone came stuck on logo to you so how can you tell this stupid thing like "WAS WORKING OK ". Any gadget works ok till gets damaged. And that is the original ALCATEL flash. It crashes because some hw fault set was working ok as told to me by the customer.set came to me stuck on logo. i flashed the set ,set got dead.you upload the new file set started powered on. some functions are malfunctioned.you told becoz of h/w issue. now on receiving incoming calls , it rings once , then shows busy.pls help me what kind of fault of this is. br sunnny |
04-05-2016, 18:26 | #9 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | [QUOTE=sunnny;11738235] Quote:
man, no idea. I provided you the original flash alcatel provides for that imei ! if you think their flash is bad then can complain directly to ALCATEL. I tell all these problems come from faulty ram or emmc. Try rehoting the emmc Br | |
