03-10-2018, 21:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Alcatel 5049w "error: reading data failed" after brute force ok! [SOLVED] Code: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM66)) Preparing to start flash mode; Preparing to open COM66 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: f2e7e081d3f1cd98a46d3262983fffa8 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem43.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM67; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x34CC0742 0x4F24C7F4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-022061-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:53:45 ERROR: Reading data failed; Time needed - 00:55:48 Log file saved to: LOG_10_03_2018_16_21_04.txt |
03-12-2018, 14:32 | #3 (permalink) |
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | I try many times, the last 2 times stuck here Code: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM66)) Preparing to start flash mode; Preparing to open COM66 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: f2e7e081d3f1cd98a46d3262983fffa8 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem43.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM67; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x34CC0742 0x4F24C7F4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-022061-1 IMEI2 [OTP 0001]: 000000-00-000000-0 Code: PROVIDER: N/A USRDATA INFO: 0x120000000 SIZE: 0xC0000000 ERROR: GET_PART_INFO; Time needed - 00:04:00 Code: PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 ERROR: GET_PART_INFO; Time needed - 00:04:00 |
03-12-2018, 15:47 | #4 (permalink) |
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Problem solved, was a driver problem, i was using driver inside, i uninstall it and use Mediatek_Driver_Auto_Installer_1.1352.00 and all work also time for brute force was 10 minutes Code: Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:10:40 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:10:51 |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
