12-28-2017, 15:04 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Alcatel 5049W not ok. (Solved) Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM24)) Preparing to start flash mode; Preparing to open COM24 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 657efc5455b8488941a55e1ef736f1ba Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xC2680742 0x4F946DA8 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-301644-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) ERROR: BRUTEFORCE FAILED; WRONG SERIAL ENTERED MAYBE !? Time needed - 03:11:39 Log file saved to: LOG_28_12_2017_11_23_39.txt Serial is correct from phone settings-About-status |
12-29-2017, 12:59 | #4 (permalink) |
Member: 69269 Status: Offline Thanks Meter: 175 | Another Alcatel 5049W unlock OK Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM20)) Preparing to start flash mode; Preparing to open COM20 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ca6585767b9035dd7976ebf5d6dad6fb Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM7; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x859C0742 0x2B84A9E0 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-302566-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 01:00:17 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 01:00:28 Log file saved to: LOG_29_12_2017_12_03_17.txt |
01-05-2018, 14:04 | #5 (permalink) |
Member: 69269 Status: Offline Thanks Meter: 175 | Unlock Ok. New Update Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM24)) Preparing to start flash mode; Preparing to open COM24 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 657efc5455b8488941a55e1ef736f1ba Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xC2680742 0x4F946DA8 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-301644-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 01:36:12 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 01:36:28 Log file saved to: LOG_5_01_2018_13_55_18.txt Thanks for the support. Great Team |
The Following User Says Thank You to abakwa For This Useful Post: |
01-08-2018, 22:29 | #6 (permalink) |
Freak Poster Join Date: Feb 2011 Location: cuba Age: 53
Member: 1524998 Status: Offline Thanks Meter: 76 | error unlock Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM55)) Preparing to start flash mode; Preparing to open COM55 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 7371622d5cc239122b02e166499f6002 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem63.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM60; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xDFB20742 0x8F94AAFC [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-393670-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) ERROR: BRUTEFORCE FAILED; WRONG SERIAL ENTERED MAYBE !? Time needed - 00:41:10 serial 554SSCVGL7L7AYUC help me |
01-09-2018, 08:15 | #7 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
01-09-2018, 14:12 | #8 (permalink) |
Member: 1524998 Status: Offline Thanks Meter: 76 | last update does not fix the error Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM55)) Preparing to start flash mode; Preparing to open COM55 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 7371622d5cc239122b02e166499f6002 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem63.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM60; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xDFB20742 0x8F94AAFC [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-393670-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) ERROR: BRUTEFORCE FAILED; WRONG SERIAL ENTERED MAYBE !? Time needed - 00:43:10 Log file saved to: LOG_9_01_2018_14_11_53.txt |
01-09-2018, 14:30 | #9 (permalink) |
Member: 1524998 Status: Offline Thanks Meter: 76 | one more try and he already did ok Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM55)) Preparing to start flash mode; Preparing to open COM55 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 7371622d5cc239122b02e166499f6002 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem63.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM60; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xDFB20742 0x8F94AAFC [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-393670-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:10:40 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:10:47 |
The Following User Says Thank You to arturoh For This Useful Post: |
01-09-2018, 14:36 | #10 (permalink) | |
I dont know which version you consider latest but you are not usiong v2731 as i said !!! Br | |
