08-15-2016, 19:25 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Albania -Durres
Member: 154346 Status: Offline Thanks Meter: 37 | %qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to enter download mode; Preparing to open COM6 Connecting; Init; Port opened; Phone detected (@oem185.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM251 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 35736907029988-6 PTH: 08 PTS: ABE PROV_ID: 5051X-2DALGB1 SBTADDR: 20:A9:0E:39:42E SWIFIADDR: 20:A9:0E:34:1D:77 HS_PN: SAA1FQ0AA10C SSN: W5KD05CMRIZ00DA Work id: 05627799 Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 35736907029988-6 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; FRPEx Done; Log file saved to: LOG_15_08_2016_20_22_10.txt Time needed - 00:00:46 this is log and phone have again frp active. im using new version 1.0.0.10265 |
08-30-2016, 12:20 | #7 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem116.inf,%qcomserialportdesc90170%;ALCATEL HS-USB Diagnostics 9017) Preparing to enter download mode; Preparing to open COM315 Connecting; Init; Port opened; Phone detected (@oem113.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM154 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 3573690xxxxxxxxxxxxxxx PTH: 08 PTS: ABE PROV_ID: 5051X-2ATUAU1 SBTADDR: 20:A9:0E:22:80:ED SWIFIADDR: 20:A9:0E:26:9E:1B HS_PN: SAA1FQ0AA10C SSN: W5KD05CMDIZ021D Work id: 04C7AD4F Done; SECURITY: XPA0OD00BR10 Size: 000002B1 Backup saved to: 357369070xxxxxxxxxxxx Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; FRPEx Done; Log file saved to: LOG_30_08_2016_16_19_14.txt Time needed - 00:00:58 thank u furious gold |
09-10-2016, 09:34 | #8 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Thailand
Member: 1013130 Status: Offline Sonork: 100.1605132 Thanks Meter: 461 | Quote:
ur phone finish ? | |
09-17-2016, 13:18 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM115 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 35736907029078-6 PTH: 08 PTS: ABE PROV_ID: 5051X-2EALIB1 SBTADDR: 20:A9:0E:38:51:81 SWIFIADDR: 20:A9:0E:2B:47:F8 HS_PN: SAA1FQ0AA10C SSN: W5KD05CMPIZ02H1 Work id: 051B65D2 Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 35736907029078-6 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; FRPEx Done; not done still same frp problem |
