08-18-2016, 15:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | alcatel 7041x flash probleme Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM11)) Preparing to start flash mode; Preparing to open COM11 Connecting; Downloading DA; Initializing; Rid: 6247b0367d9514092a6b4c95790d083d Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem214.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, 05] HW_STORAGE_EMMC: 0x4B000115 0x4D565835 0xC3930142 0xAB419AD0 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 863859-02-271428-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7041X-2BVDES1 USRDATA INFO: 0x65880000 SIZE: 0x84000000 ERROR: MODEL_MISMATCH; |
08-21-2016, 16:14 | #3 (permalink) |
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | i select 7041 and i get error in flash this model is from spain network his orgiginal firmware is 7041x-2bvdes1 here is log Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM11)) Preparing to start flash mode; Preparing to open COM11 Connecting; Downloading DA; Initializing; Rid: 6247b0367d9514092a6b4c95790d083d Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem214.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x4B000115 0x4D565835 0xC3930142 0xAB419AD0 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 863859-02-271428-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7041X-2BVDES1 USRDATA INFO: 0x65880000 SIZE: 0x84000000 Loading the file ... Cfg done ... ERROR: S_FT_FORMAT_FAIL ERROR: S_SECURITY_SF_SECURE_VER_CHECK_FAIL Time needed - 00:01:56 Log file saved to: LOG_21_08_2016_17_05_10.txt |
08-22-2016, 07:39 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | If formatting fails this can be due to some error in the emmc chip. Try other fw and if teh same error occurs then ... Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
