01-06-2017, 12:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 44
Member: 476739 Status: Offline Thanks Meter: 507 | alcatel one touch 2036X failed or read flash same error tray many model sel Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem39.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM7]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; |
07-27-2017, 13:41 | #3 (permalink) |
Major Poster Join Date: Apr 2008
Member: 742687 Status: Offline Sonork: sunilbansal Thanks Meter: 21 | alcatel 2036x done spd furious Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM158]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: 2036X-3AVDAU1 BT ADDR: BC:2A:6F:51:AA:57 SW IMEI[0]: 00000000000000 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_352597-07-180331-5_77020000_27_07_2017_18_09_46.spd IMEI: 352597-07-180331-5 UNLOCK CODE: 85891976 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_27_07_2017_18_10_25.txt Time needed - 00:01:02 |
The Following User Says Thank You to sunilbansal For This Useful Post: |
