04-13-2014, 13:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Alcatel ONE TOUCH 4010X DIRECT UNLOCK FAILED Code: Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM272); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V31.F2.P14 Hw Version: JRDHZ75_GB2_HW Reading phone info; IMEI: 869294-01-725388-0 Reading simlock info; NOTE: Most of the times one of the first variants will work ! MODEL: OT-4010 UNLOCK CODE: 3 3 2 7 0 4 1 8 MODEL: OT-4010 UNLOCK CODE: 3 7 1 4 2 9 9 7 MODEL: OT-4010 UNLOCK CODE: 3 7 6 4 0 3 5 6 MODEL: OT-4010 UNLOCK CODE: 1 9 6 6 8 6 3 6 Time needed - 00:03:55 after enter to engineering mode by *#*#3646633#*#* > SIMMeLock then all codes options are not active (means can not open after click) need help |
04-13-2014, 14:54 | #3 (permalink) | |
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | problem solved! i root and wipe with volcano box then counter were resetted. i tried to enter codes, nck was correct by FG but SP code was not calculated by FG (you can see above log) direct unlock also not done, so i calculate with LGEtool. here are correct codes Quote:
MianLinks | |
04-13-2014, 20:21 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Simply use OTSmart 468 to flash it. Flashing any 4010X flash will reset the counters. Our program works perfect and on support you find biggest FLASH DATABASE ever ! Over 1000GB of flash files. Can watch bellow flashing: Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
