06-25-2015, 15:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-4022 unlock problem. [SOLVED] When I open OTSmart v1.0.0.838, Select OT-4022, Ticked Remove SIM_LOCK > CONNECT button... without Connect Mobile with pc it is show these two line. Using library Brom_DLL_v7.1413.5 ERROR: BOOT_PHONE: where is problem? how can I unlock OT-4022 from FireFox OS ? |
06-26-2015, 13:00 | #5 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | After Press Unlock show File not Found.... Alcatel OT-4022D-2ARGSN3 ) Firefox OS. Here is Log... Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM5 Connecting; Downloading DA; Initializing; Rid: 70b68c5adac4f9f0fc3d0915a46ff98c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM8; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_NAND: [SAMSUNG] K9K8G16U0K [EC:BC:00] [SIZE=0x20000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 4022D-2ARGSN3 USRDATA INFO: 0x1A680000 SIZE: 0x04F40000 Searching data; File not found; File not found; Time needed - 00:00:05 |
06-26-2015, 15:51 | #6 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Here is Log... after try with MTK Reader. Unlock done first SIM. Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM92); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V2.P5 Hw Version: JRDHZ72_W_FF_HSPA_HW Reading phone info; IMEI: 358808-06-047053-5 Reading simlock info; Locked to: 208-01 code_cat_n: 26590150 enabled: yes tries: 0 code_cat_ns: 37748759 enabled: no tries: 10 code_cat_sp: 38921830 enabled: no tries: 10 code_cat_c: 38318558 enabled: no tries: 10 code_cat_sim: 24978636 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:10:39 |
06-26-2015, 16:10 | #7 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | YES Finally With New Version SIM Two Also Unlock done... Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM92); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V2.P5 Hw Version: JRDHZ72_W_FF_HSPA_HW Reading phone info; IMEI: 358808-06-047053-5 Reading simlock info; Locked to: 208-01 code_cat_n: 26590150 enabled: no tries: 10 code_cat_ns: 37748759 enabled: no tries: 10 code_cat_sp: 38921830 enabled: no tries: 10 code_cat_c: 38318558 enabled: no tries: 10 code_cat_sim: 24978636 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:04:19 |
The Following User Says Thank You to razib143 For This Useful Post: |
