Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 09-04-2014, 04:18   #1 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
Question Alcatel OT-5036A , UNLOCKING FAILED [SOLVED]
Alcatel OT-3056A , UNLOCKING FAILED
NEED IDEAS IN THIS. PLS.
Old 09-04-2014, 09:39   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,564
Please post the log to see
Old 09-04-2014, 10:33   #3 (permalink)
Member: 1960717
Sonork: 100.1638403
Thanks Meter: 34
Please post the log to see ????????????????
Old 09-04-2014, 13:23   #4 (permalink)
Member: 15022
Sonork: 100.53452
You must use OTSmart for OT-5036 !!!!
br
The Following User Says Thank You to .:hack3r2k:. For This Useful Post:
Old 09-04-2014, 15:21   #5 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
br
I used that sir.but it says boot error.
Old 09-04-2014, 15:32   #6 (permalink)
Member: 15022
Sonork: 100.53452
Because drivers badly installed. Must run REMOVE.bat, INSTALL.bat and if you are on WIN7 must run spinstal.exe as administrator !
See the video bellow. It shows the procedure
http://www.youtube.com/watch?v=hpuFlxhFiFQ
Old 09-06-2014, 02:42   #7 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
PROBLEM SOLVED !!!
my mistake, its 5036A , sorry sir,kindly edit post. thanks
Using library Brom_DLL_v7.1347.5
Searching phone;
Phone detected (@oem88.inf,%mtk_preloader%;PreLoader USB VCOM Port)
Preparing to start flash mode;
Preparing to open COM13
Connecting;
Downloading DA;
Initializing;
Rid: e995a2ca815914daaffec1024ad6d289
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem88.inf,%mtk_sp_da%;DA USB VCOM Port)
TRYING TO OPEN COM14;
DEVICE INFO:
BB CHIP: MT6572_S00 [CA01, 00, 6572, FF]
HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xC06F1058 0xD9A0D64C [SIZE=0xE9300000]
IMEI1 [OTP 0001]: 013822-00-300421-7
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: 5036A-2CSAPH1
USRDATA INFO: 0x5C6C0000 SIZE: 0x8CC40000
Searching data;
Locked to: 515-03
code_cat_n: 8314257238 enabled: yes tries: 10
code_cat_ns: 9223347423 enabled: no tries: 10
code_cat_sp: 8121283788 enabled: no tries: 10
code_cat_c: 0378675370 enabled: no tries: 10
code_cat_sim: 5202284770 enabled: no tries: 10
code_cat_ns_sp: 53297761 enabled: no tries: 5
code_cat_sim_c: 86817778 enabled: no tries: 5
Phone unlocked; Remove battery and cable;
Time needed - 00:00:59
The Following User Says Thank You to bronce For This Useful Post:
Page generated in 0.16844 seconds with 8 queries
