10-20-2015, 18:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-5042T Unlock problem... Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM61)) Preparing to start flash mode; Preparing to open COM61 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 862e84969b5928568780bbfd2774d6b3 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x6E7C124B 0xE7621E79 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-265515-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x7DB00000 Searching data; ERROR: S_DA_INVALID_RANGE ERROR: S_SECURITY_INVALID_PROJECT Phone unlock failed; Time needed - 00:00:04 Log file saved to: LOG_20_10_2015_17_27_24.txt |
10-20-2015, 21:24 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | This phone has the fw damaged. Re-flash it with the original fw from the support. Let the phone start, after unlock it Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-21-2015, 11:14 | #3 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | I Downloaded File from support 5042T-2[X=A,B]TBUS1.osp. 01. During flash Show this Error... 02. After Flash IMEI Unknown ( Emergency Calls only ) ( How To Solve this problem )? Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM61)) Preparing to start flash mode; Preparing to open COM61 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 862e84969b5928568780bbfd2774d6b3 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x6E7C124B 0xE7621E79 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-265515-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x7DB00000 Loading the file ... Cfg done ... Formatting file system now... ERROR: S_DA_INVALID_RANGE ERROR: S_SECURITY_INVALID_PROJECT Time needed - 00:04:57 Log file saved to: LOG_21_10_2015_09_46_06.txt Flashing screen shot And after power on try to unlock but same Error Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM61)) Preparing to start flash mode; Preparing to open COM61 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 862e84969b5928568780bbfd2774d6b3 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x6E7C124B 0xE7621E79 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-265515-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x7DB00000 Searching data; ERROR: S_DA_INVALID_RANGE ERROR: S_SECURITY_INVALID_PROJECT Phone unlock failed; Time needed - 00:00:05 Log file saved to: LOG_21_10_2015_10_06_31.txt |
10-21-2015, 14:18 | #5 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306894 Status: Offline Sonork: 100.1575449 Thanks Meter: 68 | have same problem flash phone show same error and lose imei Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM21)) Preparing to start flash mode; Preparing to open COM21 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: c3c27c89025e9962e8b92c18fc64d06f Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM23)) TRYING TO OPEN COM23; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x6B16124B 0xBB62FDD6 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-xxxxx-x IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x7DB00000 Loading the file ... Cfg done ... Formatting file system now... ERROR: S_DA_INVALID_RANGE ERROR: S_SECURITY_INVALID_PROJECT Time needed - 00:01:26 Log file saved to: LOG_21_10_2015_09_12_49.txt |
10-22-2015, 01:18 | #6 (permalink) |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM22)) Preparing to start flash mode; Preparing to open COM22 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2bc6b1ac30bc5eea1abc7ddd9e99b618 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM252)) TRYING TO OPEN COM252; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x753C124B 0x25721787 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-230552-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x7DB00000 Searching data; ERROR: S_DA_INVALID_RANGE ERROR: S_SECURITY_INVALID_PROJECT Phone unlock failed; Time needed - 00:00:03 pls helppppppppppppppppppppppppppppppppppppppppppppppp ppppppppppppppp i try 3 phone same |
