06-23-2016, 10:20 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | Alcatel OT282 how to repair? Product: OT-282 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Rebuild security region failed! Error Code: 4084 Please double check the cable and handset connection! Try it again! Make your handset power off, plug in the UART cable! Product: OT-282 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Rebuild security region failed! Error Code: 4084 Please double check the cable and handset connection! Try it again! i use goldensecurity file from ot-280 as u say. also i try flash it with ot-282 firmware but also i get error but flashing started and goes about 40%. UART cable! Product: OT-282 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 861941008910989 Provider ID: N/A Security information version: N/A Downloading flash image now... Flash handset image failed! Error Code: 1930 Please double check the cable and handset connection! Try it again! |
06-26-2016, 15:04 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Quote:
09-19-2016, 09:49 | #7 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | Thx a lot for help! I use external power and phone is alive now. But i have another problem, i need russian lp for it. What is simular model or u may be can put russian lp on support? |
