05-04-2015, 16:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | Alcatel OT4037T from tmobile cannot unlock from FGbox, please I need help.t.y[SOLVED] here is the logs: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem201.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM242 Connecting; Downloading DA; Initializing; ERROR: Connection failed ! ERROR: BOOT_PHONE; I followed your video tutorial from the last year of may you made. but I do not have luck to unlock it please kindly need your help on this., Thank you |
05-05-2015, 10:07 | #2 (permalink) |
Member: 621698 Status: Offline Thanks Meter: 405 | hack, please kindly post here MT65XX usb driver because I use 2pcs. windws 7 pc and 2pcs, windows XP but still has the same problem I do not have access thru support area ( my account is expired ) Thank you in advance. |
05-05-2015, 13:19 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Driver is included in the archive. Your error is related to bad drivers. Driver install procedure you can see here Last edited by .:hack3r2k:.; 05-05-2015 at 13:56. | |
07-30-2015, 19:07 | #5 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Accra, Ghana
Member: 390671 Status: Offline Thanks Meter: 31 | Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem137.inf,%mtk6218%;MTK USB Port) Preparing to start flash mode; Preparing to open COM62 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 994883b0e0e22166fdd526a47e834e46 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem138.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM134; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, 05] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x08480142 0x23811558 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 014068-00-544754-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4037T-2BTBUS1 USRDATA INFO: 0x6D080000 SIZE: 0x7C800000 Searching data; Locked to [SIM1]: 310-16 code_cat_n: 1430536895 enabled: yes tries: 3 code_cat_ns: 2874462120 enabled: no tries: 10 code_cat_sp: 2370798480 enabled: no tries: 10 code_cat_c: 2327914999 enabled: no tries: 10 code_cat_sim: 1085071997 enabled: no tries: 10 code_cat_ns_sp: 1096448867 enabled: no tries: 5 code_cat_sim_c: 2524533128 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:25 |
The Following User Says Thank You to alesisd4gh For This Useful Post: |
