08-24-2013, 11:35 | #31 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Use Unlock Codes for Cell Phone | iTunes iPhone Factory Unlock Best Price to get the code Br | |
09-20-2013, 09:04 | #32 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Searching phone; Phone detected (@oem186.inf,%dev_single%;USB Single Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V7.F4 Hw Version: JRD76_11A_ATT_HW Reading phone info; IMEI: 013107-00-706293-6 Reading simlock info; Unlock codes: network_key: 0303423014 network_subset_key: 1087725139 service_provider_key: 0751929113 sim_key: 3841231316 If the counter is blocked or the phone is not asking for codes, insert and accepted sim and type ###765*08#; Time needed - 00:00:15 |
The Following User Says Thank You to msmobile For This Useful Post: |
11-15-2013, 02:13 | #35 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Sure, it's 871A, I read codes pressing space key: Searching phone; Phone detected (MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V8.F10 Hw Version: JRD76_11A_GEMINI_HW Reading phone info; IMEI: 013160-00-xxxxxx-x Reading simlock info; Unlock codes: SET1 OF CODES: (IF THEY DONT WORK TRY SET2) network_key: 0347951258 network_subset_key: 2882511985 service_provider_key: 0686315064 sim_key: 1281186658 SET2 OF CODES: network_key: 0347951258 network_subset_key: 2882511985 service_provider_key: 0686315064 sim_key: 1281186658 If the counter is blocked or the phone is not asking for codes, insert and accepted sim and type ###765*08#; Time needed - 00:00:21 The codes are wrong... |
11-15-2013, 02:22 | #36 (permalink) |
No Life Poster Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Try USING the (* STAR) Key and post the result Sometimes different code are generated when the * STAR key is pressed NB I can see that SET 1 and SET 2 are the same codes |
11-15-2013, 09:25 | #37 (permalink) | |
Br | |
11-16-2013, 19:22 | #39 (permalink) | |
Do you live under a rock or what ? Unlocking Software | OTZ FLASHER | PACK6 Br Last edited by .:hack3r2k:.; 11-16-2013 at 19:35. | |
