01-08-2017, 17:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | Alcatel POP 4 Plus - 5056d - FRP Reset don't work Phone detected (@oem371.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM66 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: PTH: 11 PTS: A49 PROV_ID: 5056D-2FALWE1 SBTADDR: F0:34:04:96:53:96 SWIFIADDR: F0:34:04:96:53:99 HS_PN: SAA1F52WA10C SSN: J2KC04BQ5HZ01BJ Work id: 04FD14E5 Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; FRPEx Done; Log file saved to: LOG_8_01_2017_17_46_43.txt Time needed - 00:00:16 Tried with new version software, but phone still lock. |
02-09-2017, 16:37 | #10 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 966475 Status: Offline Thanks Meter: 8 | Mobile off, I connect the usb cable and it asks for a driver I give the location of the file of the driver those that indicate but they are not installed, I have tried xp and windows 7 |
02-09-2017, 16:56 | #11 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
You have the drivers in the mentioned archive. If you dont manage to install some drivers add me over skype and i will do it for you Br | |
02-10-2017, 08:41 | #12 (permalink) |
Member: 966475 Status: Offline Thanks Meter: 8 | Already got to install the drivers but as they say above does not work for the model 5056d, the procedure is turned off with the cable usb and then I press firehorse and of the list that appears in the model 5056 and pulse dojob but does nothing |
02-11-2017, 18:05 | #13 (permalink) |
No Life Poster Join Date: Sep 2012
Member: 1813192 Status: Offline Thanks Meter: 60 | onnecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 3573 PTH: 08 PTS: ABE PROV_ID: 5051X-2ETBMK1 SBTADDR: 20:A9:0E:41:542 SWIFIADDR: 20:A9:0E:3F:A7:0C HS_PN: SAA1FQ0AA10C SSN: W5KD05CMQIZ053U Work id: 05D452EF Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 35736907036901-0 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; FRPEx Done; Log file saved to: LOG_10_02_2017_00_07_04.txt Time needed - 00:01:16 alcatel 5051x not work frp |
02-11-2017, 18:45 | #14 (permalink) |
Junior Member Join Date: May 2009 Location: Bucuresti
Member: 1039386 Status: Offline Thanks Meter: 1 | FRP lock ot5056D Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem152.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM345 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 3569990....628-2 PTH: 13 PTS: A49 PROV_ID: 5056D-2FALE11 SBTADDR: 20:A9:0E:4B:3D:82 SWIFIADDR: 20:A9:0E:51:6C:76 HS_PN: SAA1F52WA10C SSN: J2KC05CIPIZ025Y Work id: 054BC3F3 Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 356999....2628-2 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; FRPEx Done; |
