10-20-2016, 23:30 | #11 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Care drivers=NOKIA DRIVERS> Find that usb device on the device manager, right click it and install forcefully the alcatel ones Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-29-2016, 06:50 | #15 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1206897 Status: Offline Sonork: Aleandros Thanks Meter: 34 | Quote:
ok now i see phone and software work but frp not removed, why? this is log: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem210.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM88 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 35736807********* PTH: 08 PTS: ABE PROV_ID: 5051D-2BALWE1 SBTADDR: 20:A9:0E:09B:14 SWIFIADDR: 20:A9:0E:09:B4:0D HS_PN: SAA1FQ2AA10C SSN: 41KD06CN4IZ013W Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 04F56291 Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 3573680******** Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; FRPEx Done; Log file saved to: LOG_29_10_2016_07_45_16.txt Time needed - 00:09:57 | |
The Following User Says Thank You to NAVAKO For This Useful Post: |
