08-10-2017, 08:45 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 899329 Status: Offline Thanks Meter: 6 | ALE-L21 no signal after flash I have flashed some firmware from support, but nothing fix the problem. Flashed NV too, repair imei but still no signal. Any help would be appreciated |
08-10-2017, 09:36 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Can you post the logs of flashing, nv write and repair !? Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
08-10-2017, 12:04 | #3 (permalink) |
Member: 899329 Status: Offline Thanks Meter: 6 | i flashed via fastboot mode the file ALE-L21_C432B601_Firmware_Europe_Nonspecific.cfs and after via update mode Looking for a device in upgrade mode No devices detected in upgrade mode Looking for a device in fastboot mode Device found: W3D7N16715016339 10/8/2017 1:13:49 μμ Starting to write device in FASTBOOT mode... Device found: W3D7N16715016339 IMEI: 862939031065390 Build number: :BalongC52B311 Product model: hi6210sft Extracting partition MODEMIMAGE... Writing MODEMIMAGE partition with file MODEMIMAGE MODEMIMAGE partition UPDATE ...OK Extracting partition MODEMNVM1... Writing MODEMNVM1 partition with file MODEMNVM1 MODEMNVM1 partition UPDATE ...OK Extracting partition MCUIMAGE... Writing MCUIMAGE partition with file MCUIMAGE MCUIMAGE partition UPDATE ...OK Extracting partition HIFI... Writing HIFI partition with file HIFI HIFI partition UPDATE ...OK Extracting partition DSP... Writing DSP partition with file DSP DSP partition UPDATE ...OK Extracting partition DTIMAGE... Writing DTIMAGE partition with file DTIMAGE DTIMAGE partition UPDATE ...OK Extracting partition TEEOS... Writing TEEOS partition with file TEEOS TEEOS partition UPDATE ...OK Extracting partition TRUSTFIRMWARE... Writing TRUSTFIRMWARE partition with file TRUSTFIRMWARE TRUSTFIRMWARE partition UPDATE ...OK Extracting partition SECURETYSTORAGE... Writing SECURETYSTORAGE partition with file SECURETYSTORAGE SECURETYSTORAGE partition UPDATE ...OK Extracting partition NVME... Writing NVME partition with file NVME NVME partition UPDATE ...OK Extracting partition FASTBOOT1... Writing FASTBOOT1 partition with file FASTBOOT1 FASTBOOT1 partition UPDATE ...OK Extracting partition FASTBOOT... Writing FASTBOOT partition with file FASTBOOT FASTBOOT partition UPDATE ...OK Extracting partition RECOVERY... Writing RECOVERY partition with file RECOVERY RECOVERY partition UPDATE ...OK Extracting partition RECOVERY2... Writing RECOVERY2 partition with file RECOVERY2 RECOVERY2 partition UPDATE ...OK Extracting partition BOOT... Writing BOOT partition with file BOOT BOOT partition UPDATE ...OK Extracting partition SYSTEM... Writing SYSTEM partition with file SYSTEM SYSTEM partition UPDATE ...OK Extracting partition CACHE... Erasing CACHE partition Partition CACHE erased Writing CACHE partition with file CACHE CACHE partition UPDATE ...OK Extracting partition CUST... Erasing CUST partition Partition CUST erased Writing CUST partition with file CUST CUST partition UPDATE ...OK Extracting partition USERDATA... Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition with file USERDATA USERDATA partition UPDATE ...OK Software written 10/8/2017 1:21:24 μμ Writing device finished OK Looking for a device in upgrade mode COM80: Android Adapter PCUI (COM80) COM82: DBAdapter Reserved Interface (COM82) 10/8/2017 1:23:53 μμ Starting to write device in UPGRADE mode... File to update: ALE-L21_C432B601_Firmware_Europe_Nonspecific.cfs Validating file... Detecting port... Preparing to write... Writing partition: SHA256RSA...OK Writing partition: CRC...OK Writing partition: CURVER...OK Writing partition: VERLIST...OK Writing partition: EFI...OK Writing partition: MODEMIMAGE...OK Writing partition: MODEMNVM1...OK Writing partition: MCUIMAGE...OK Writing partition: HIFI...OK Writing partition: DSP...OK Writing partition: DTIMAGE...OK Writing partition: TEEOS...OK Writing partition: TRUSTFIRMWARE...OK Writing partition: SECURETYSTORAGE...OK Writing partition: NVME...OK Writing partition: FASTBOOT1...OK Writing partition: FASTBOOT...OK Writing partition: RECOVERY...OK Writing partition: RECOVERY2...OK Writing partition: BOOT...OK Writing partition: SYSTEM...OK Writing partition: CACHE...OK Writing partition: CUST...OK Writing partition: USERDATA...OK Software written 10/8/2017 1:53:40 μμ Writing device finished OK the phone turns on but it says emergency calls only and no bluetooth wifi I flashed the ALE-L21_NV_partitions_backup file before that. I used the huawei module to fix imei bt wifi but the problem is the same. Before all these I used the factory file ALE-L21_MAA001075_Factory_firmware_general_Android_5.0 _EMUI_3.1.fcff and I think that this is the reason that the model changed from ALE-L21 to hi6210sft. When I flash the model with ALE-L21 roms via update or via roms from furious the model is still hi6210sft do you have any suggestions? thanks in advanced |
08-10-2017, 14:06 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
