Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 10-22-2007, 11:58   #1 (permalink)
bimson22vn's Avatar
Member: 534040
Thanks Meter: 13
All LG M1 module Unlock and flash not work.......Please help me!
When unlock or flash LG in module M1 then not work ...Please help me!
Thank's
Old 10-22-2007, 14:12   #2 (permalink)
Member: 267789
Thanks Meter: 5
same problem
I also have the same problem
Old 10-22-2007, 14:20   #3 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 346
It's working . Try to keep the power on button pressed until it boots up ...
Old 10-22-2007, 15:11   #4 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 51,854
Also be sure you have PACK 1 inside.
Old 10-22-2007, 17:16   #5 (permalink)
Member: 167930
Thanks Meter: 5
pack1, pack2 that will bull**** you when your not familiar with FG, yah you have to make new clip
for other update rather than another S**t pack3 good for you and to other user.
Old 10-22-2007, 21:58   #6 (permalink)
Member: 15022
Sonork: 100.53452
Not so hard read instructions. 38 modeules use pack 1 and 2 pack 2. Requires minimum MEMORY to remember this and minimum will to read a sigle sticked thread.
Old 10-23-2007, 02:40   #7 (permalink)
bimson22vn's Avatar
Member: 534040
Thanks Meter: 13
@usernome I did keep power on but not working , after update Maintainance v1.0.0.513 all module in FGBox working fine
@.:hack3r2k:. I did update fimware Pack1 first but not working
Thank's for reply.Please help !
Old 10-23-2007, 02:47   #8 (permalink)
bimson22vn's Avatar
Member: 534040
Thanks Meter: 13
one problem is another after update maintainance v1.0.0.513 not see KE seria Module
Old 10-23-2007, 05:49   #9 (permalink)
Member: 188484
Thanks Meter: 113
upgrade your box with pack 1 and will see ...WORKING URA FG is the best bla bla bla .....and read instructions ..
Old 10-23-2007, 09:26   #10 (permalink)
bimson22vn's Avatar
Member: 534040
Thanks Meter: 13
Update Pack1 OK but not working !
Old 10-25-2007, 21:45   #11 (permalink)
Member: 15022
Sonork: 100.53452
You must restart the exe aswell afterwards.
Old 10-25-2007, 22:22   #12 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 974
Yes do exactly: press format (wait till it finish) -->close maintenance-->disconnect the box and connect it again-->open maintenance-->select pack1-->press update firmware-->close maintenance-->disconnect the box and connect again-->open lg module and continue IF IT DOESN'T CONNECT TRY AGAIN
Old 10-25-2007, 22:24   #13 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 974
don't forget to select the right cable,and check the +5v and Fbus Mbus
6030 menu key not working, please help me gsm_surya Nokia Hardware & Hardware Repair 5 02-14-2008 17:42
HWK not working please help me pedro7208 HWK 5 07-31-2005 20:05
3300 KEYS"0" "4" not working please help me mohammed Nokia Hardware & Hardware Repair 0 05-10-2004 22:21
C55 - JavaActivator not worked - please help me MrK E-Gold Based Phones 2 04-19-2003 23:32
Page generated in 0.38424 seconds with 9 queries
