12-27-2016, 20:38 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Kosovo
Member: 272517 Status: Offline Sonork: 1604061 Thanks Meter: 68 | Amazon Fire after unlock not conected with Wifi (solved) Software engine version: 1.0.0.10469 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01418000063173-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; |
12-28-2016, 07:39 | #2 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | well can't understand how unlock interrupt Wi-Fi .. how did you know it was connected before ?? |
12-29-2016, 13:52 | #3 (permalink) | |
Member: 272517 Status: Offline Sonork: 1604061 Thanks Meter: 68 | Quote:
Thanks Fire phone (Unlocked GSM): Fire OS 4.6.6.1 Transfer the software update file to your Fire phone: Connect your Fire phone to your computer using the included USB cable. If you have a lock screen set, unlock your phone so it can be accessed by your computer. Open the Fire folder, and then drag and drop the software update file into the Internal storage folder. After the file transfer is complete, disconnect the USB cable from your Fire phone and your computer. Swipe down from the top of the screen (or swivel your phone) to open the Quick Actions panel, tap Device, and then tap Install System Update. Your device will restart during the software update. | |
The Following User Says Thank You to beli_gl For This Useful Post: |
