11-08-2009, 08:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: pakistan
Member: 141121 Status: Offline Sonork: 100.1580885 Thanks Meter: 20 | amoi s1 unlock problem iam using gpg white cable 039 Press Power On shortly ! Phone Detected ! Loading ... Error ... ! Time needed - 00:00:18 |
11-08-2009, 16:46 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 45
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | What phone do you have here thread says AMOI S1 and then the post says MOS1 both are different models and use different modules S1 is to be unlock by pack 5 and USB cable and MOS1 has its own module and uses RJ45 please confirm what the phone is. BR |
The Following User Says Thank You to mbcommunication For This Useful Post: |
11-09-2009, 09:17 | #7 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | NEVER HAD PROBLEM WITH THESE TYPE OF PHONE UPGRADE UR BOX AGAIN WITH PACK 1 THEN OPEN THE PHONE CONNECT TP HERE IS TESTED UNLOCK REPORT Press Power On shortly ! Phone Detected ! Loading ... Boot info: FuriouSTeaM GSM DEVELOPEMENT Imei: 357345002XXXXX-9 Flash ID 1: 0089:8810 0101 Flash ID 2: 0089:880D 0101 Reading info ... Firmware info: Amoi 9201-V12.0 Loading ... Loading ... Booting system ... Please wait ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Setup done ... Phone code: 0000 Security locks disabled ... Phone unlocked ! Time needed - 00:01:12 BR YASERMALIK |
The Following User Says Thank You to yasermalik For This Useful Post: |
11-10-2009, 10:02 | #9 (permalink) | |
Member: 141121 Status: Offline Sonork: 100.1580885 Thanks Meter: 20 | testpoint Quote:
i conect testpoint with gnd as software says but without open fone gnd batt terminal. | |
11-10-2009, 12:04 | #13 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Change com port according to your Box port. as i can see, you select com1 as port. change it |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
11-10-2009, 18:12 | #14 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | is ur f gold box is on comm no 1 ????? if yes then connect tp again and press unlock button dnt remove tp and post result |
amoi wp s1 unlock problem | zaheerseria | VygisToolbox | 3 | 05-21-2009 23:30 |
S1 unlock problems / delays | capobanan | Universalbox | 2 | 05-20-2009 15:27 |
amoi wp s1 unlock problem? | zabih | VygisToolbox | 1 | 05-12-2009 17:38 |
Amoi S1 unlock :::SOLVED in V2.1.0::: | paulb | PolarBox 3 | 24 | 03-19-2009 14:57 |
s1 unlocking problem | Stylo_GSM | Universalbox | 1 | 02-04-2009 23:17 |
