05-20-2017, 23:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Azumi l2z says unlock but still ask for code Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem383.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM90]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 86:19:C1:E79:5A SW IMEI[0]: 354684-08-226158-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 303A0000 Reading NV; NV saved to : NV_000000-00-000000-0_354684-08-226158-0_65310001_20_05_2017_18_00_26.spd IMEI: 354684-08-226158-0 UNLOCK CODE: 80284733 ERROR: Simlock not enabled ! Phone is unlocked; Log file saved to: LOG_20_05_2017_18_00_43.txt Time needed - 00:00:27 |
05-20-2017, 23:18 | #2 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
05-20-2017, 23:30 | #3 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | [QUOTE=Yusuf Lawal;12509153]Use miracle box to read flash then upload and send link to me in PM[/Q i dont have miracle , but i read with nck |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
05-21-2017, 04:11 | #5 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | [QUOTE=Yusuf Lawal;12509253]https://mega.nz/#F!D1gAVKIT!pTAuqgnNWobIHvmFKjPOJQ Sent from my LGLS775 using Tapatalk |
05-21-2017, 09:00 | #7 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | maybe u try the code inside here http://forum.gsmhosting.com/vbb/f296...ution-2193522/ |
05-21-2017, 09:51 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | [QUOTE=maxpatri9;12509257] Quote: you have on the support the patched firmware AZUMI_L2Z_EN_PT_ES-2PATCHED.spd . Simply write it ! Br Sent from my iPhone using Tapatalk Pro Last edited by .:hack3r2k:.; 05-21-2017 at 10:32. | |
05-21-2017, 13:47 | #9 (permalink) | |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | [QUOTE=.:hack3r2k:.;12509615] Quote:
Sent from my LGLS775 using Tapatalk | |
05-22-2017, 12:12 | #12 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Get https://forum.gsmhosting.com/vbb/****************************/?pawzpdxsxf1alc5 and write it. Must work ok after . Also should be unlocked ! Br | |
05-22-2017, 15:11 | #13 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | all fail ask for code yet ,i flash 4 diferent rom with diferent result. Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem383.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM90]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 86:19:C1:E79:5A SW IMEI[0]: 354684-08-226158-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 303A0000 Reading NV; NV saved to : NV_000000-00-000000-0_354684-08-226158-0_65310001_22_05_2017_10_10_09.spd IMEI: 354684-08-226158-0 UNLOCK CODE: 80284733 ERROR: Simlock not enabled ! Phone is unlocked; |
05-26-2017, 17:21 | #15 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | Maxpatri9 here the solution... https://mega.nz/#!IEo3CKRJ!oi0klUXjo...LmJnxiwy8H0CWk |
The Following User Says Thank You to daryl007 For This Useful Post: |
