08-16-2011, 13:23 | #1 (permalink) |
Junior Member Join Date: Apr 2008 Location: Barcelona, Spain
Member: 755642 Status: Offline Thanks Meter: 5 | Best solution for unlocking vodafone 246 with pack 3 to mode LG cable GS 101 it will work with all three version of furious gold box gold metal box , plastic box or new 2011 version. and best thing is you dont need to open ur box and do modification Things you will need is LG gs 102,101 unlocking cable a spare usb cable of any device our motive is to use 5v dc from it first of of change TX and RX ( cables on point 2 and 3 ) simply open the connecter from front and check the color of all point and note down but do not change any cable from there as all cables are from china and could be a mess and you end up with damaged connecter. cut the cable insulation from center and change the TX with RX means the cable on number 2 pin connect with no 3 and 3 connects to no 2 now we have change tx and rx but the second part of this modification is to provide cell 5 v dc at point no 1 so we check the usb cable normally as international standard red wire in usb or in any device have +ve but dont take my word for it. check it with multi volt meter here is very important point must be noted that we need to cut the cable coming from r45 side point no 1 and we only solder wire going towards mobile phone connecter cause we have to supply voltage only to cell not to the furious gold it might can cause damaged to box so we connect +ve of usb to pin no 1 and cut the other end that is coming from rj45 side and we connect -ve to point no 8 that is -ve now we have modded cable for vodafone 246 and it will work every time ... with out any problem and make sure you put battery in the phone software will say without battery but ignore that also you don't need to think will it work with my box as this will work with any model of furious box farhan from Barcelona, Spain Last edited by londonkinani; 08-16-2011 at 13:29. Reason: misspled |
The Following 2 Users Say Thank You to londonkinani For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
