04-07-2010, 13:01 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Then put incorrect password 10 times and then set a new one, obviously it's IMPOSSIBLE to generate security code to a blackberry with just imei or using USBcable at the moment |
04-07-2010, 13:38 | #8 (permalink) |
Junior Member Join Date: Jan 2008
Member: 692056 Status: Offline Thanks Meter: 2 | Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded at BlackBerry Software Site Step 2 Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe (Newer 4.2 OS Devices Goto Options/Security Options/General Settings/Wipe) on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 Close the Desktop Manager if it is open. Step 5 From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 Open the Desktop Manager. Step 7 Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. BlackBerry - Smartphone Software - BlackBerry Applications - Smartphone Downloads http://www.blackberryforums.com/medi...icy/policy.bin works 100% |
The Following User Says Thank You to copilu_ovy For This Useful Post: |
04-07-2010, 14:01 | #10 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
its so simple 10 times give worng code set reset after reset the set no need to put new password just connect the set with cable and open FG bb exe and read the code ...i tested this method and working .... | |
how to reset user code in bb8800 [SOLVED] | rajesh_ch | FuriousGold | 4 | 05-28-2009 10:20 |
Putting Maps on BB8800 | Malaw | GPS devices , Navigators & Maps | 0 | 03-25-2009 13:56 |
Bb8800 | Boyteks | BlackBerry (RIM) | 0 | 03-03-2009 19:09 |
Problem with BB8800 form 02 Ireland | isra60 | BlackBerry (RIM) | 1 | 01-13-2009 12:58 |
BB8800 - Load flash image failed !!! Help me, please.. | catvuvn | BlackBerry (RIM) | 5 | 01-11-2009 18:11 |
