01-15-2010, 17:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | Blackberry unlocked.... But, Initialization failed. SOLUTION HERE !!! |
01-15-2010, 19:59 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mor
Member: 1006514 Status: Offline Thanks Meter: 640 | Quote:
i had the same problem with 2 BB 8310 with same problem and solved by flashing and leaving it without battery for few hours and worked very well | |
The Following User Says Thank You to mrx3net For This Useful Post: |
01-15-2010, 21:20 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: here
Member: 20953 Status: Offline Thanks Meter: 94 | Initialization failed seems to me like a hardware problem... I tried to fix a bold once with that problem and flashed it like 5 times with different firmwares, wiped it clean, unlocked it... etc! nothing will fix it! so I am assuming it's hardware |
The Following 2 Users Say Thank You to zapped For This Useful Post: |
01-16-2010, 17:39 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | if you find error (severity) 4 on logs I think will be hw problem. br, free1600 |
The Following User Says Thank You to free1600 For This Useful Post: |
01-16-2010, 17:44 | #7 (permalink) |
Member: 1006514 Status: Offline Thanks Meter: 640 | as i told you i had the same problem with 2 bb 8310 i flashed both and leave them without battery the whole night and when i back on the morning i found phones working |
01-18-2010, 17:27 | #9 (permalink) |
Member: 1006514 Status: Offline Thanks Meter: 640 | Well i'm just trying to help you ! does the phone show initizlization failed with sim card inside on not ? try to do this it's should work too / i read this on crackberry forums try inserting some thin plastic or something above the SIM in the slot so it presses down harder. i had this problem too and this seems to fix it. |
01-21-2010, 08:22 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | HI, problem Solved nice to know that Better to Use Small Sticky notes (used by most Mobile Serivce center stick on mobile write Fault etc) Apply those 2 on back of SIM thats all its Thick enough to Press it better in sim jacket thankx mrx3net |
BlackBerry 8700g - JVM Error 102 - Solution here! | Cryspim | BlackBerry (RIM) | 10 | 12-21-2010 17:56 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
unlocked BB 8170g but sim initialization fail! | msajum | BlackBerry (RIM) | 0 | 12-12-2009 17:32 |
Blackberry Initialization failed Solution | gujjar_brothers | BlackBerry (RIM) | 5 | 02-08-2009 12:37 |
N95 when unlocking but testpoint failed.. but ok i have the pm what next ? | DjSwift | MT-BOX | 1 | 04-08-2008 21:46 |
