10-15-2018, 08:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 41
Member: 114705 Status: Offline Thanks Meter: 22 | Blaupunkt sl04 unlock not working [SOLVED] Phone detected (@oem124.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM64); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V111.P2 Hw Version: ZECHIN6580_WE_N_HSPA_HW Reading phone info; IMEI: 355480-09-003250-4 Reading simlock info; ERROR: Simlock data error (41) Time needed - 00:00:59 Log file saved to: LOG_15_10_2018_09_39_02.txt I testing 2 pc windows 10 and win 7 but unlock not working other sl04 unlock ok. please help me thx |
10-15-2018, 12:53 | #3 (permalink) |
Member: 114705 Status: Offline Thanks Meter: 22 | hi not working: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM73)) Preparing to start flash mode; Preparing to open COM73 Connecting; Downloading DA; Initializing; Rid: 89b22cc92bb740b034f56a53e33464eb Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem124.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM191; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0x980FA532 0x39A40F8C [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xB1000000 SIZE: 0x11FF80000 Searching data; File not found; ST33A004 File not found; File not found; File not found; File not found; File not found; File not found; ERROR: EXT4_SIMLOCK_REMOVE failed; Time needed - 00:00:01 Log file saved to: LOG_15_10_2018_13_50_15.txt How to connect phone? |
10-16-2018, 07:37 | #7 (permalink) |
Member: 114705 Status: Offline Thanks Meter: 22 | very thx. Direct unlock working Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM73)) Preparing to start flash mode; Preparing to open COM73 Connecting; Downloading DA; Initializing; Rid: 89b22cc92bb740b034f56a53e33464eb Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem124.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM191; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0x980FA532 0x39A40F8C [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xB1000000 SIZE: 0x11FF80000 Searching data; File not found; ST33A004 Locked to [SIM1]: 460-01 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:08 Log file saved to: LOG_16_10_2018_08_35_18.txt |
The Following User Says Thank You to Nono_k@ For This Useful Post: |
