03-15-2013, 12:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: PT
Member: 600502 Status: Offline Sonork: 100.1653742 Thanks Meter: 91 | Boston codes not work Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : May 15 2010 18:38:00 RELEASE DATE : Nov 18 2009 03:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-4735 IMEI : 35210204069235-0 BLUETOOTH ADDR : 34 42 18 94 11 00 TAG_ID:M76XX-TS UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; UNLOCK CODE [OLD]: 30524582 UNLOCK CODE [NEW]: 29656868 COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:42 hi codes not work in support only romania flash, wich flash for Portugal? thanks |
03-15-2013, 12:34 | #2 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Quote:
03-15-2013, 15:39 | #3 (permalink) |
Member: 600502 Status: Offline Sonork: 100.1653742 Thanks Meter: 91 | if so i like that you confirm if have portuguese you donīt say that. (99% of phones are from their owners and the phone have numbers) and if don`t have, i like to be inform from you. or if you like, do the codes correct and if you ned something for that(dump or other) i can do that thanks |
03-15-2013, 15:52 | #4 (permalink) |
03-15-2013, 16:18 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | u dont se ? UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT |
03-15-2013, 16:57 | #9 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | All languagues available confirmed by hack3r2k |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
