01-25-2010, 12:51 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Still thinking
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | cu 920 flash any solution for lg cu920 hand on Atnt logo flash with 2 file from furious support area no lock handset still hand on startup logo CU920-DZ_IMG-V10s-DEC-12-2008-ATT-U. CU920-MSM-V10h-FEB-05-2008-ATT-US |
02-02-2010, 21:06 | #2 (permalink) |
Junior Member Join Date: Oct 2005 Location: dr
Member: 189239 Status: Offline Thanks Meter: 2 | reply try with this software and firmware here http://gsmvn-support.com/index.php?d...CU920_Factory/ |
The Following User Says Thank You to candela For This Useful Post: |
04-15-2010, 13:36 | #4 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: 000000ffff
Member: 211652 Status: Offline Thanks Meter: 120 | Quote:
once it flashed the phone become okay but when turn off it show EMERGENCY MODE one the screen.... when try to flash with furious it stop when software say put the battery out and then Power on the phone and connect to usb.... it doesn't goes ONLINE gave errror....it this time the screen show Re-flashing.... as i put the battery out and than put it again it show EMERGENCY MODE.... is there any soulation.... br | |
04-27-2010, 04:05 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Using the QFG.exe with the latest firmware on the support site I get this: Searching phone ... MODEL : CU920 INIT FLASHING ENGINE ... OK; NV READ SKIPPED; UPLOADING STARTED; WORKING IN EMERGENCY MODE; EFS ERASING; RESETTING PHONE ! WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; Error ... ! Time needed - 00:11:19 Tried it 3 times but every time when it says unplug/replug battery after the 25 sec startup sequence it just errors out and shows "Re-flashing" on the phone screen. I made sure that the device manager picks up the modem port (3) and diag port (4) but fails to restore the EFS. I had to use the free LGMDP to fix the problem but I'm sure Hack can fix it Br, BillA |
how can ulock lg CU 920 | askaralikp | VygisToolbox | 9 | 04-01-2011 19:50 |
can not unlock cu 920 | WIDE | VygisToolbox | 6 | 03-25-2009 21:45 |
CU 920 - during unlock aplication closed .... | pcmaniac.pl | Easy-Unlocker | 2 | 12-12-2008 22:52 |
CU 920 - during unlock aplication closed .... | pcmaniac.pl | Easy-Unlocker | 5 | 12-12-2008 15:03 |
problem with cu-920 | renzox | PolarBox 3 | 3 | 08-26-2008 09:57 |
