02-23-2011, 13:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: could'nt found yet
Member: 223973 Status: Offline Thanks Meter: 155 | Dell Streak unlocking Problem [SOLVED MORE OR LESS] oftware engine version: 1.0.0.6384 Searching phone ... MODEL : DELL STREAK (MINI5) ENTERING DOWNLOAD MODE; ENTERED; BOOTLOADER VER: 12-324012-AUSB1AM-0 ALLOCATING BUFFERS; PREPARING TO DUMP SENSITIVE DATA; DECODING DATA; at this point soft asks me if the device is locked ?? The procedure m following is 1.Insert restricted sim 2.when phone shows the text box enter unlock code 3.i press the volume button and remove battery back and battery phone turns off. 4.Put back the battery and bat back 5.insert usb cable What m doing wrong kindly point me to correct direction plz P.S m on 1.6 Br K@mi |
02-23-2011, 13:44 | #3 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: New Delhi, India Age: 45
Member: 190823 Status: Offline Sonork: 100.1604079 Thanks Meter: 554 | Quote:
I Tried Morethen 100 times but problam is still same. After that I have Unlocked With Dell Streak Client because Customer Not me More Time. This Solution want easier to Unlock. Thanks & Regards Rajinder Aggarwal | |
02-23-2011, 16:00 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | I guess one of the problems it's do fast the procedure, If you must remove battery cover procedure can't be fast. Also do you press volume up or down? |
02-23-2011, 21:16 | #9 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Toronto, Canada
Member: 178829 Status: Offline Thanks Meter: 24 | I have a slightly different problem? My streak is identified in Hardware Manager as QUALCOMM diagnostic interface 3197 (As opposed to 9002). I have uninstalled, reinstalled, rebooted, etc etc. and every time it comes back as 3197. Using your drivers from support. Using latest .exe and everything. I did the process a dozen times now, each time faster and faster, last time the whole Battery removal, replace, and USB attach was under 3 seconds, so it cant be that. Any ideas? |
02-24-2011, 08:21 | #12 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | I have also same poblem of drivers then i solve it by uninstall then gave the path manuallay and use option "HAVE A DISK" Then its ask for file then locate it and my port now same as shown in hack pics.and after try mainy time with old version got same error then i use latest version and it works perfect 1.0.0.6396. |
02-24-2011, 09:09 | #13 (permalink) |
Freak Poster Join Date: May 2008 Location: inside APPLE SHOP
Member: 781691 Status: Offline Thanks Meter: 22 | unlock done thanx to furious team Software engine version: 1.0.0.6396 Searching phone ... MODEL : DELL STREAK (MINI5) ENTERING DOWNLOAD MODE; ENTERED; BOOTLOADER VER: 12-407705-AUSB1AM-0 ALLOCATING BUFFERS; PREPARING TO DUMP SENSITIVE DATA; DECODING DATA; NETWORK: 02226623 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESETTING; Time needed - 00:01:09 |
02-24-2011, 14:53 | #15 (permalink) | |
Member: 223973 Status: Offline Thanks Meter: 155 | Quote:
Br | |
The Following User Says Thank You to kamiran For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
