09-02-2019, 12:29 | #5 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Attach here the backup saved during the process. Also repeat thsi process using latest version. Pls retry to flash the phone before using the file from the support Br |
09-02-2019, 17:40 | #6 (permalink) | |
Freak Poster Join Date: Jul 2009
Member: 1073402 Status: Offline Thanks Meter: 35 | Quote:
already flashed with support firmware (Madrid-L21A 9.0.1.184 (C431E5R2P1) _Firmware_9.0.0_r3_EMUI9.0.1.osp) same negative result does not change imei -backup saved during the process https://www.4shared.com/rar/9fYqZZta...EC8F6EC_D.html | |
09-02-2019, 23:11 | #7 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Going to check it tomorrow Sent from my iPhone using Tapatalk Pro | |
09-03-2019, 00:16 | #8 (permalink) |
Freak Poster Join Date: Aug 2011 Location: pretoria
Member: 1636627 Status: Offline Thanks Meter: 24 | Also have same issue. When i try to change imei it shows imei done but phone only goes to recovery after imei repair operation done and when i try to flash with file from support phone goes on normaly but imei not changed please fix this. I tried on y5 2019 anf y6 2019 both have same issues. Thanks |
09-03-2019, 08:29 | #9 (permalink) | |
Is normal because after flashing you must repeat the process of imei repair and that time all will work fine. Br | |
09-03-2019, 08:51 | #10 (permalink) | |
Hi i checked and all seems to be fine. Please contact me on telegram here https://t.me/joinchat/AXUxsBdkbULJ6EvYhVGoUg . I still suggest trying with latest version as well. Also i see your support is expired since 06 Oct 2016 . Maybe is time to renew. Br;0 | |
