06-27-2018, 18:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | echo prim [SOLVED] how to unlock this phone ? when i choose file flash for patch unlock software do nothing and what is the boot key ? thx in advance |
07-09-2018, 11:44 | #6 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | thx now file is ok but hang after connect with phone Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem85.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM43]; |
07-09-2018, 19:25 | #13 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | finaly it boot the solution is 1+3 then connect usb pfff im tired lol Code: Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem74.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM6]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 07:07:10:01:02:20 SW IMEI[0]: 359783-08-035870-6 SW IMEI[1]: 359783-08-035871-4 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 10388000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_9_07_2018_19_26_05.txt Time needed - 00:04:10 |
