06-02-2011, 10:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Entering codes on LG phones... Gsm-Hacking News: How to enter codes on LG! Special shark release! If you miss any let me know here or at blog and I will add. Let's do it the reference so you can have your instructions easily Last edited by FTEAM_MODERATOR; 09-06-2011 at 19:47. |
The Following 6 Users Say Thank You to FTEAM_MODERATOR For This Useful Post: |
06-02-2011, 11:59 | #5 (permalink) |
No Life Poster Join Date: Apr 2010 Location: U.K. / INDIA
Member: 1283682 Status: Offline Thanks Meter: 304 | Small contribution ... If not find there LG KB770 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG GB250, GB220 Power on your phone without SIM card Enter 2945#*71001# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG GT505 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG BL40 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*40# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG BL20 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*20# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG GW520, GB250 Insert an original simcard and turn phone on (code can also be entered without SIM card) Enter sim PIN if required Enter 2945#*71001# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG Viewty GW300 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*700# From the menu that pops up select "SIM unlock" Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG G910 Insert a non original simcard and turn phone on Enter sim PIN if required Select "Emergency mode" Enter 2945#*71001# Sim unlock mode pop up Select Netlock Enter unlock code you received from Cellcorner and press OK The phone will then reboot and the unlock is complete LG KC910, KF910 (aka LG *****) Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*910# Sim unlock mode pop up Enter unlock code you received from Cellcorner and select Reboot The phone will then reboot and the unlock is complete. LG *****, KE850, ME850 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*8501# Sim unlock mode pop up Enter unlock code you received from Cellcorner and select Reboot The phone will then reboot and the unlock is complete. LG WATCHPHONE GD810 Insert a non original simcard and turn phone on Insert PIN Phone says "Invalid sim card" Select "Emergency calls" Enter 2945#*71001# Sim unlock mode pop up Select netlock Enter your 16-digit unlock code and press ok The phone will then reboot and the unlock is complete. LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security > Sim Lock > Network > Deactivate Enter supplied unlock code Your phone is unlocked LG U400 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*9636# The phone will then prompt "Unlock sim". Press "OK" The phone will then prompt "Network Unlock". Press "OK" Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. he phone will give you message "Succeess" Go back to the main screen and enter 2945#*88110# The phone will then prompt "Unlock sim". Press "OK" The phone will then prompt "Network Unlock/Lock" but if you scroll down you will see a message Enter SP Lock. Enter SP Code Then press "OK" Your phone is unlocked LG U8110 Power on phone with a non-original SIM card inserted Type 277634#*# Select "Sim Unlock" Enter supplied unlock code Your phone is unlocked LG U8150, other UMTS models Power on phone with a non-original SIM card inserted Type 277634#*# Go to menu "SIM Lock" Enter supplied unlock code Your phone is unlocked LG U8210 Power on phone with a non-original SIM card inserted Type 277634#*# Go to "Sim Test" and type 2945#*# Select "Sim Unlock" Enter supplied unlock code Your phone is unlocked LG CU400, CU500 Cingular AT&T Power on phone with a non-original SIM card inserted Phone will display "Invalid SmartChip" If the phone doesn't display "Invalid SmartChip" power off and on, then try again Type 159753#*# Select "1 Unlock USIM", then "1 network lock" Phone will display "Enter NCK, Remaining 5" Enter the 8 digit unlock code Select "OK" Your phone is unlocked LG CU575, CU515 Trax Cingular AT&T Power on phone with a non-original SIM card inserted Phone will display "Invalid SmartChip" If the phone doesn't display "Invalid SmartChip" power off and on, then try again Type *#865625# Select option 1 and then again select 1 Enter the supplied unlock code Your phone is unlocked LG CU720, TU720, other SHINE series Power on phone with an original (from the locked carrier) SIM card inserted Type *#865625#CODE where CODE is the unlock code provided by CellCorner Select "OK" Your phone is unlocked If this didn't work you can also try to repeat the above steps with a non-original SIM card inserted LG CE110 Prior to unlocking reset the phone to "Factory Default" Power on phone with a non-accepted SIM card Select "Cancel" - phone will displays "Phone restriction code" Enter supplied unlock code Select "OK" Your phone is unlocked LG CE500 Power on phone with Cingular SIM card Type 2945#*7101# Select Settings > Security > Sim Lock > Network > Deactivate Enter supplied unlock code Your phone is unlocked LG KG275 Power on phone with non original SIM card Type in the code you received from Cellcorner.com Press "Send" key Your phone is unlocked If this didn't work append #*# to the end of the entered code LG C3310 Power on phone with a non-original SIM card inserted Type 2945#*3311# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked LG Invision CB630 Power on phone with a original AT&T SIM card inserted Type *#865625# in the phone menu Press "Call" Enter supplied unlock code Your phone is unlocked LG CU915 Power on phone with a original SIM card inserted Type *#865625#CODE where CODE is the unlock code provided by CellCorner Press "OK" Your phone is unlocked LG KE970 SHINE Power on phone with an original (from the locked carrier) SIM card inserted Press telephone icon at bottom of screen to bring up the phone keypad Type 2945#*990# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked or Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*9701# Press "Call" Enter the supplied unlock code when prompted LG KE990, KU990 VIEWTY Power on phone with an original (from the locked carrier) SIM card inserted Press telephone icon at bottom of screen to bring up the phone keypad Type 2945#*990# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KF700 aka LG VIRGO Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*700# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KF750 aka LG SECRET Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*750# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG GC900, GT360, GT810, KC550, KM500, KM900, KP230, KP270, KP500, KP501, KS360, Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*71001# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KS360 aka QWERTY Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*71001# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KF755 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*755# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KF390, KF390q Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*390# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KF600 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*600# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KS20 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*20# and 2945#*990# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked LG KG245 Vodafone Australia Insert an original (from the locked carrier) SIM card and power on the phone Type 2945#*7101#. This will activate the extra menu Select "Settings" -> "Security" -> "Sim lock" -> "Network" Select "Deactivate" Enter the 8-digit unlock code and press "OK" Phone will display "Done" Your phone is unlocked LG KG800 CHOCOLATE, TG800 CHOCOLATE Insert an original (from the locked carrier) SIM card and power on the phone While in standby enter 2945#*5301#. This will activate the extra menu Select "Settings" -> "Security" -> "Sim lock" -> "Network" Select "Deactivate" Enter supplied unlock code and press "OK" Your phone is unlocked LG T5100 Power on phone with a non-original SIM card inserted Type 2945#*5301# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked LG C2200 Power on phone with a non-original SIM card inserted Type 2945#*2201# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked LG G7020 Power on phone with a non-original SIM card inserted Type 2945#*70001# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked LG C3100, C3380, F2300, KE260, KE970, KG120, KG220, KG240, KG280, KG290, KG800 CHOCOLATE, KU250, KU380, TG800 CHOCOLATE Insert an original (from the locked carrier) SIM card and power on the phone LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KE970 press 2945#*9701# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KG800 press 2945#*7101# LG KU250 press 2945#*250# LG KU380 press 2945#*380# A Secret menu will appear Select "Settings", "Security" and then "Sim lock" Enter supplied unlock code and press "OK" Your phone is unlocked LG KU311, KU800, L600V, U8150, U8210, U8500 Insert a non-original SIM card and power on the phone LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# |
The Following 7 Users Say Thank You to C Singh For This Useful Post: |
06-02-2011, 23:01 | #7 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | 30% of this list are new lg, most of this are android How to Enter Unlock Codes for LG GM360 Viewty Snap 1. Power on your LG Viewty GM360 with the original SIM card in. 2. Enter 2945#*360# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. How to Enter Unlock Codes for LG GS290 Cookie Fresh 1. Power phone ON with original SIM 2. Type 2945#*290# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for Optimus One P500 1. Switch the phone with no sim card inserted. 2. Dial 2945#*500# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GT400 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*400# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GT450 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*450# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GT540 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*540# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GW620 1. power phone ON with original SIM 2. type 2945#*620# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GM205 1. switch on your phone with original working simcard 2. enter code 2495#71001# .. nothing will show in the screen. 3. now go to menu > setting > security > simlock > network lock > deactivate: enter your unlock code in it How to Enter Unlock Codes for LG GW820 eXpo 1. Power on your LG GW820 eXpo with the original SIM card in. 2. Enter 2945#*700# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. 5. Your LG GW820 eXpo may automatically reboot. How to Enter Unlock Codes for LG GM205 1. Power phone ON with original SIM 2. Type 2945#*71001# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GB250, GB220 1. Power on your phone without SIM card 2. Enter 2945#*71001# 3. From the menu that pops up select "SIM unlock" 4. Enter unlock code you received from us and press OK 5. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GW520 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG Viewty / GW300 1. Power on your LG Viewty GW300 with the original SIM card in. 2. Enter 2945#*700# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. (Entering multiple incorrect unlock codes may permanently lock your phone!) 5. Your LG Viewty GW300 may automatically reboot and should now be unlocked! How to Enter Unlock Codes for LG BL20 1. insert original sim card and turn phone on. 2. Enter 2945#*20# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok How to Enter Unlock Codes for LG BL40 1. insert original sim card and turn phone on. 2. Enter 2945#*40# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok How to Enter Unlock Codes for LG C1100 - First you must put in an allowed simcard, then : - type 2945#*1201#. - Goto Menu/Settings/Security Settings/Sim Locks - Select 'Locktype'/Deactivate and Enter the code. How to Enter Unlock Codes for LG GT505 - power phone ON without SIM - type 2945#*505# to enter unlock menu - enter unlock code How to Enter Unlock Codes for LG GB250 - power phone ON without SIM - type 2945#*71001# to enter unlock menu - enter unlock code How to Enter Unlock Codes for LG GW520 - power phone ON without SIM - type 2945#*71001# to enter unlock menu - enter unlock code ! How to Enter Unlock Codes for LG KB770 1. Power on phone with original SIM card 2. Type 2945*#770# 3. In the menu that appears select Sim unlock 4. Enter supplied unlock code 5. Your phone is unlocked How to Enter Unlock Codes for LG KP170 1 - Switch ON your phone with a T Mobile Sim inserted 2 - Press telephone icon at bottom of screen to bring up the phone keypad 3 - Then compose : 2945#*170# 4 - A menu will pop up, select Unlock Usim 5 - Then Select Network Lock 6 - Enter your unlock code and press ok (you only have 10 attempts) 7 - The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG CU-515 1.Put a SP-locked sim in the phone, phone say invalid smart chip 2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code Phone will be unlocked! How to Enter Unlock Codes for LG TE365 1. Power on phone with original SIM card 2. Type *#0001#code# 3. Your phone is unlocked How to Enter Unlock Codes for LG CT810 (Incite) 1. Power on phone with original SIM card 2. Type 2945#*810# 3. In the menu that appears select Sim unlock 4. Enter supplied unlock code 5. Your phone is unlocked How to Enter Unlock Codes for LG CB630 (Invision) 1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2) Dial this into the LG Incite's phone menu 3) *#865625# 4) Press CALL. 5) It should you ask you for the code. How to Enter Unlock Codes for LG U830 1. Have your unlock code handy. 2. InserI a 3 SIM card in the phone and switch power on. 3. Enter the following key sequence 94471877#*# 4. Select the option ‘unlock USIM’. 5. Select the option ‘network unlock’ 6. Enter your unlock code. 7. Handset should now display ‘network unlock success’. 8. Handset will now restart. How to Enter Unlock Codes for LG KF300 1. Put wrong simcard 2. Phone alert 'insert correct card' 3. Right under in screen you see deblokkeren (dutch) 4. Click on it en click 'Network lock off' 5. Insert code! How to Enter Unlock Codes for LG KP100 1. Insert original sim card and turn phone on. 2. Enter 2945#*20001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF755d 1. Insert original sim card and turn phone on 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work) 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG Incite CT-810 - Insert a SIM from the original network - 2945#*810# will show the unlock menu - Enter unlock code How to Enter Unlock Codes for LG KP265 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*265# 3 - Then go to MENU > SETTINGS > SECURITY 4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE 5 - ENTER NCK (your Unlock Code) How to Enter Unlock Codes for LG ME550 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*71101#. 3 - Menu will appear, go to settings > security > sim lock 4 - Enter NCK ( Unlock Code ) and press OK. How to Enter Unlock Codes for LG TU915 - Switch ON your phone with an allowed SIM Card - Then compose: 2945#*9701# - It should you ask you for the code. OR Enter *#865625# then enter your 16 digits code. How to Enter Unlock Codes for LG KF390, KF390q and CF360 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Select ok. Done! :How to Enter Unlock Codes for LG G910 1. Insert an invalid simcard and turn phone on. 2. Insert PIN 3. Phone says \"Invalid sim card\" 4. Select \"Emergency calls\" 5. Enter 2945#*71001# 6. Sim unlock mode pop up 7. Select netlock 8. Enter your 16-digit unlock code and press ok 9. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG *****, KE850 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes for LG CT810 1. insert original sim card and turn phone on. 2. Enter 2945#*810# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG VU CU915 & CU920 (Vu) 1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked ! How to Enter Unlock Codes for LG U310 1. Turn ON the phone without SIM Card : 2. Enter 815118#*# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG iQ 1 - Switch ON mobile with a not Allowed SIM Card, 2 - If phone ask, enter the PIN code of your SIM Card 3 - Now phone will ask you to enter the unlocking code ! How to Enter Unlock Codes for LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500, GT810, GC900, GT360 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF700 (aka LG Virgo) 1. insert original sim card and turn phone on. 2. Enter 2945#*700# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KC910, KF910 (aka LG *****) 1. insert original sim card and turn phone on. 2. Enter 2945#*910# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF750 1. insert original sim card and turn phone on. 2. Enter 2945#*750# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF600 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG U970 1. Insert original sim card and turn phone on. 2. Enter 2945#*970# 3. A menu will pop up, select Unlock Usim. 4. Select Network Lock. 5. Enter the unlock code and ok. How to Enter Unlock Codes for LG U300 1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider) 2 - Enter Code : 815118#*# 3 - then phone will ask to enter NCK How to Enter Unlock Codes for LG C2000 1) Insert non-Cingular SIM card 2) Power on the handset - phone will display "phone restricted" 3) Select "Cancel" - phone will display "phone restriction code" 4) Enter the SIM Unlock code 5) Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes for LG KU990 Viewty & KE990 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete. or 1. Without sim phone power "ON" 2. Hold "camera" + "lock" button 3. You will get key pad write 2945#*990#. 4. Press active code. 5. Your cellphone will be restart 6. Turn off cellphone and insert your sim (internation sim) 7. Enjoy your unlocked phone ! How to Enter Unlock Codes for LG TU720 - LG CU720 (Shine) 1) Power ON your phone with not allowed sim card (one that didn't come with the phone) 2) Type *#865625# 3) the phone will ask you to input the unlock code twice, just input the unlock code 4) Device is now unlocked How to Enter Unlock Codes for LG CE110 1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK’" - the handset is successfully unlocked How to Enter Unlock Codes for LG GR500 (Xenon) 1) Insert not-allowed SIM card 2) Power on the handset- phone will display "phone restricted" 3) Select "Cancel" - phone will display "phone restriction code" 4) Enter the SIM unlock code 5) Select "OK" - the handset is now successfully unlocked or 1. insert original sim card and turn phone on. 2. Enter 2945#*9701# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. or After turning on your mobile phone, press: *#865625# Press Yes to continue. Enter the 16 digit Subsidy Unlock Code Enter the 16 digit Subsidy Unlock Code, again. Device should say: “Network Lock Deactivated” Phone may automatically reboot How to Enter Unlock Codes for LG CU320 1) Power on the handset 2) In Idle screen, input the special code "277634#*#". 3) Enter the SIM Unlock code 4) Access the submenu "SIM Test" in Phone Test Mode. 5) Input the special code "2945#*#". 6) Access the submenu "SIM Unlock" which is just activated after the special code. 7) Input the 8-digit Unlock code in the "Enter unlock code" input screen. 8) It will be unlocked. How to Enter Unlock Codes for LG CU400 & CU405 1) Insert non-Cingular SIM card" 2) Power on the handset - Phone will display "Invalid SmartChip". 3) Enter 159753#*# 4) Enter the 8 digit SIM Unlock code 5) Select "OK". 6) The handset will be unlocked. How to Enter Unlock Codes for LG CU500 1) Insert non-Cingular SIM card. 2) Power on the handset. Phone will display "Invalid SmartChip" 3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 5) Enter the 8 digit SIM unlock code 6) Select "OK" 7) The handset is now successfully unlocked. How to Enter Unlock Codes for LG CU515, CU575 (Trax) 1) Put a non-Cingular sim in the phone 2) Phone says invalid smart chip 3) Now enter *#865625# then select option 1 and then again select 1 4) Enter your 16 digits code 5) Device should say: Network Lock Deactivated 6) The handset is unlocked. How to Enter Unlock Codes for LG U8150 1 - Switch ON your phone with a NOT Allowed SIM Card, 2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #, 3 - Go to menu "SIM Lock", 4 - Enter the Unlock Code we send to you. How to Enter Unlock Codes for LG U400 1. Insert the network SIM in the handset which has given u the LG U400. 2. Enter 2945#*88110#. 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 6. It should give you the message Success. 7. Come back to the main screen and Enter 2945#*88110#. 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 10. Then press OK How to Enter Unlock Codes for All other LG models 1 - Switch ON your phone with an Allowed SIM Card, 2 - Then compose : 2945#*5101# - (if you have a LG 510w) 1945#*5101# - (if you have a LG 1200 & B1200) 2945#*5221# - (if you have a LG 5200 & 52200) 2945#*5301# - (if you have a LG 5300) 2945#*5401# - (if you have a LG 5400) 2945#*70001# - (if you have a LG 7020) 2945#*7101# - (if you have a LG 7100) 2945#*1201# or 2945#*70001# - (if you have a LG 1100) 2945#*70001# - (if you have a LG7250T) 2945#*2201# - (if you have a LG C2200) 2945#*5301# - (if you have a LG T5100) 2945#*3311# - (if you have a LG C3310) 3 - Go to "Menu" and then to "Settings", 4 - Then select "Security", 5 - To finish select "Network Provider" and select "Deactivate" 6 - Enter the Unlock Code we send to you. How to Enter Unlock Codes for LG To Classify models For the next models you must to insert the original SIM: LG KF245c press 2945#*7101# LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KE970 press 2945#*9701# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KG800 press 2945#*7101# LG KU250 press 2945#*250# LG KU380 press 2945#*380# After that will appear an secret menu, go to settings-security- sim lock ,enter NCK and press OK. For next models insert a not allowed SIM ,not the original SIM: LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG U400 press 2945#*88110# LG KC550 press 2945#*71001# LG KU580 press 2945#*580# LG KT520 press 2945#*520# LG KF750 press 2945#*750# LG KF600 press 2945#*71001# LG KG275 press 2945#*20001# LG KU380 press 2945#*380# LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KS500 press 2945#*500# LG KP270 press 2945#*270# LG KF240 press 2945#*240# or 2945#*2401# LG KG290 press 2945#*7101# LG KU250 press 2945#*250# this latest 40 models maybe are alredy listed but after 20/30 post's i can make one post with all LG and no double models listed if u want. |
The Following 3 Users Say Thank You to Boshko_Alfa For This Useful Post: |
06-02-2011, 23:11 | #9 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | I will try to do something better based on PDF using In design software but if I'm able it will take some time since I'm pretty busy with exams. At the moment I will just keep the blog entry updated |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
06-03-2011, 09:54 | #10 (permalink) |
Member: 1283682 Status: Offline Thanks Meter: 304 | Even try to add that pdf on official website so that users can also download list along with new updates in LG module. Its more easy in place of asking or opening new threads in forum ..... |
The Following User Says Thank You to C Singh For This Useful Post: |
06-05-2011, 11:50 | #12 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Do you see any PDF file? Also what is the matter of enter into one sticky? And, last but not less important. Everyday people upload files from support area out of support area. So, what sense it makes to you to upload to support area if you will add a second later to megaupload or similar? |
06-13-2011, 15:41 | #15 (permalink) |
Member: 1283682 Status: Offline Thanks Meter: 304 | How to enter code LG P990 ? To enter unlock code for LG P990 You need: 1. Insert the sim card which works out your phone 2. Enter 2945#*990# 3. window appears for the code 4. Enter the code nck received 5. the phone is unlocked |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
