11-10-2008, 16:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! This is full list of the most common questions of our customer and it will be updated daily. Q: What OS (operating system) are your softwares compatible ? A: Windows XP/2K/Vista. Q: I just got my box and i would like to install drivers. What to do ? A: There are two drivers to install on first use. First get FG_FTDIDRIVER.rar from support, extract in one folder and after connect box to usb cable. In this moment windows will request this driver and just point him the correct directory. After get from support FG_SMARTCARDDRIVER.zip, extract in one fodler, right click on ini file and choose install. End these operations by resetting pc. Q: I'm trying to unlock new NECs and use TREO module TXT to code features but i'm allways getting 'Error..' or 'ERROR: 00' why !? A: First of all dongle must be upgraded with PACK 2. After kindly check and read following links: 1. Redirect to Furious-Gold new Blog 2. Redirect to Furious-Gold new Blog Q: I just got unlock data from a TREO. How i get code ? A: Use TREO module 'TXT TO CODE' feature and read before FuriousTeam - 1st in world solutions provider - THE BLOG » Unlocking TREO 650 and 680 online. Q: I just code from and LG EGOLD LITE mode but no way to enter it. What i do ? A: Flash inside mg160bP16FL55-V10A-724-05-MAR19-2007 or kg275 AFR V10a and insert a restricted sim after flash and u'll be able to enter the code. Q: U890 can be unlocked using 64K sim ? A: Yes it can. Q: I try to unlock one Blackberry and i get 'This version too old or cannot be used for unlocking'. Why ? A: You must flash phone with firmware from support and after try code reading again. Q: How do i enter codes in Blackberry phones ? A: Type 'MEPPD' or 'MEPD' and after 'MEPP2' or 'MEP2'. Q: Why do i get BAD LOGIN when i try to login support ? A: One main possible reason is the fact you didnt activated the box. Q: I'm using Maintainnace and i get socket errors and connection is refused . Why ? A: Most probably reason is the fact u are using and old version. Q: Some softs in Furious dont start or dont work properly. Why ? A: Check if u'r dongle is updated using correct PACK or if you use latest version of the modules. Allways check forum and BETA folders. Q: WHen i try use modules i get 'License not found !'. Why this ? A: Use Maintainance and generate license urself. Q: HOW TO UNLOCK U970 and U830 ? A: 1. TO UNLOCK U970 PLEASE CONECT PHONE IN EMERGENCY MODE (2+5+PWR ON) AND CHECK 'FORCED MODE' ON SOFTWARE. AFTER FULL FLASH USING U970_UNLOCK.*** 2. TO UNLOCK U830 PLEASE CONECT PHONE IN EMERGENCY MODE (2+5+PWR ON) . AFTER FULL FLASH USING U830_UNLOCK.*** Q: How do i unlock U300 and U890 (64K sims included) using FuriouS ? A: 1. Flash using special file from support 2. Detach phone from usb cable 3. Insert orginal simcard or any sim card accepted by phone 4. Put the usb cable or charger (phone start charging) 5. Wait 10 sec then power on the phone. 6. Go in phone menu at 'unit converter' (the phone will restart) 7. Quickly remove battery, change current sim with other one (64k, 128k) and put battery back and wait. P.S: if phone results on 'no network' then write nv file for u890 from support and then repeat the procedure from 2 to 7. Q: How to unlock U880 and U900 using FuriouS ? A: 1. Flash phone using unlock/tempunlock file from support 2. Insert a restricted sim and when 'SIM LOCKED'/'USIM BLOCATA' shown on screen press S.O.S key or type 142358#*# code blindly. 3. That's all ! Q: How i can correctly update correct PACK using MAINTAINANCE module ? A: 1. CHOOSE PACK YOU NEED (PACK1 OR PACK 2OR PACK 3) 2. UPDATE FW Q: What modules require PACK 1 written in dongle ? A: AMOIMOS1.exe BLACKBERRY.exe DBTELJ6.exe DRAGON.exe GR1000.exe LG3G.exe LGKE.exe LGM1.exe LGM2.exe LGQ.exe LOBSTER.exe MICROSNAPPER.exe NEC344.exe O2x1.exe ONDA.exe PANA10X.exe PANTECH.exe PHILALC.exe QFG.exe QUANTA.exe SHARP3G.exe SIEMENSC62.exe TOSA.exe TS21i.exe TS605.exe TS608.exe VK3E.exe MOTO.exe VLE5.exe Q: What modules can i run using PACK 2 ? A: NECM2.exe TREO.exe BenQ1.exe BenQ2.exe Lobster544.exe MT.exe NG.exe O2x7.exe PA.exe Qualcomm.exe VK.exe Q: What modules can i run using PACK 3 ? A: SEFUT.exe FBS.exe VLECOSTO.exe MTK_ALC.exe VODAFONE.exe SAGEM.exe LGM3.exe DISNEY.exe ZTEAD.exe LOBCOSTO.exe MTKONE.exe Q: I get following message when i use PHILALC module 'Signature file not found ! Re-install application. Error ... ! Time needed - 00:00:10'. Whats wrongs ? A: Be sure u have installed latest setup and that SEEDS.bin is near module exe. Q: How to enter unlock codes on Blackberry phones ? A: How to SIM Unlock the device: 1 Insert SIM into device 2 Power phone on and Turn off the radio (Turn Wireless Off option) VERY IMPORTANT. 3. Go to the "Tools" screen 4. Select "Settings"'' 5. Select "Options" THEN SELECT ADVANCED OPTIONS 6. Select the "SIM Card" option 7. Type "MEPPD" (please note that you will not see what you type on the screen) 8. Type "MEPP "ALT" 2" 9. Enter the Unlock Code 10. Press enter (press on Trackball) 11 .Reboot device. Device is now unlocked Q: I have an MG160 / KG 275 dead and cannot be booted after flash with wrong file. What i do ? A: MG160 / KG 275 dead and cannot be booted after flash with wrong file. Solution to repair. 1. Please use fully charged battery. 2. Run Proper module ( Currently LG KE Module v. 1.0.0.2013 ) 3. Deattach battery from phone , phone must be not connected to cable. 4. In sw Module choose proper com port, "write flash" job, and file MG160bP16FL-55-V10a-724-05-MAR-19-2007+1.bin from support. 5. Press "Do Job". 6. When the message " Press power On" appeared in window - Connect phone to cable and Only NOW insert battery. Flashing should start. 7. After job done, you can read codes from it , or flash any other proper flash file from support. Important! Solution is tested and work only for phones killed by wrong file flashed using Furious sw. We do not have any idea if it may work for phones killed using any other sw. ! Q: How i read codes from TREO 650 and use them to unlock it ? A: Reading Your phones Unlock Codes 1. Run treo read code software 2. remove any card inside in phone 3. Remove Treo Battery Cover & Power on your Treo 4. Connect USB Sync Cable (as supplied with phone) 5. Place Phone in “Test Mode” - Press and Hold Button on USB Cable - Using Pen Press and hold for 1 second Reset button in Back of Treo - Release reset button, then release Active Sync button on Cable - Display should be red/blue etc and detail boot loader version - Phone is now in Test Mode If Windows now detects a new device (this will happen the first time you put a treo 650 into test mode, then you will need to do the following (you will only need to do this once) 1. A new hardware wizard will appear. Select “No, not this time” if asked about connecting to the internet 2. Then on the next screen Select “Don’t search, I will choose driver to install.” Click on the “Have Disc … “ button 3. Select the drivers, direct windows to the folder containing the Treo HTTC drivers, if presented with a Windows warning about Microsoft signing of drivers. Choose “Continue Anyway” 4. Windows will now install the drivers. 5. Click on finish on next screen 6. Windows has finished installing New Hardware .You will only need to do this once per PC. 7. Now click “Do Job” on SW, (codes should be displayed in under 5 Seconds) Entering Codes 1. Remove Treo battery, unplug cable 2. Insert incorrect SIM card (1 the phone does not accept) 3. Power on Treo-650, “Sim not allowed” is displayed, click “ok” 4. Go to the dial pad, and use the stylus to enter code exactly as displayed in the software. Then press “Dial” 5. Phone will reset and display “sim lock removed” Phone Unlocked !!!! Q: I can't connect my siemens phone with FBS ! Whats the problem ? A: Try select and use for communication COM 1. Q: What LG Qualcomm models are supported for FULL UNLOCK and FULL REPAIR ? A: KU800, KU450, L600V, KU311, U990, KU990, CU500, CU500V, MU500, TU550, TU500, TU500S, TU500F, CU400, CU405, CU320, CU720, TU720, CU575, TU575, CU515, TU515, KU380, KU385 and maybe other phones in future. Q: I have white screen after flashing KE500/ME5xx. What to do ? A: 1. GET FLASH HERE 2. OPEN LGKE v1.0.0.2503, SELECT WRITE FLASH, DO JOB AND SELECT FILE YOU JUST DOWNLOADED 3. SELECT 'FULL ERASE BEFORE', PRESS 'DO JOB' AND WAIT FLASH TO FINISH 4. POWER ON PHONE, CONNECT TO IT KG800 RJ45 CABLE (NOT KE500 FLASHING CABLE), SELECT IMEI CHANGE, WRITE INSIDE THE BOX IMEI FROM THE STICKER AND PRESS DO JOB 5. ENJOY A REPAIRED AND UNLOCKED PHONE ! Q: How to flash Blackberry when soft not shown ? A: Copy from C:\Program Files\Common Files\Research In Motion\Shared\Loader Files the folder for 7700, 7100, 7200 (depending phone model) in C:\ for example and after when flasher dont show anything press add and select from c:\ folder just copied ! AFter contents display press cancel and repeat operation. This time will show u all files from start. Q: Where to get INVISIBLE SHELL+EDITOR ? A: Can be downloaded from: MEGAUPLOAD - The leading online storage and file delivery service MEGAUPLOAD - The leading online storage and file delivery service and RapidShare: 1-Click Webhosting RapidShare: 1-Click Webhosting editor is included inside so users can update and customize thereselves the shell, quick guide for shell and editor is included too in pdf format anyone who want to share databases have to copy: database.DB, database.MB, database.PX, database.XG0, database.XG1, database.YG0, database.YG1 if any problem then read bellow: just go to the bde folder... execute bde.bat (this exectute the c:\windows\system32\regsvr32.exe bdeinst.dll command... if your windows isnt in this folder... just change it) in the installation it said that i dont have enough space to install on C partition... just ignore the error and install this then app works ok! its the borland database engine that is missing in computers! usually computers have mdac or simply delete old shell and BDE directory under c:\program files\common files\borland shared\bde then reinstall bde.bat and run shell it should work like a charm. Q: Where to get dhru_1 shell+editor ? A: http://gsmblack.com/fgshell.exe Q: How to use latest maintainance update Redirect to Furious-Gold new Blog Q: HOW TO UNLOCK LG OMAP SERIES ? EXAMPLE FOR KE520. FOR REST SIMILAR STEPS MUST BE FOLLOWED FIRST STEP: 1. WRITE KE520_EEP (IN CASE YOU DONT HAVE WORKING BACKUP FROM UR PHONE) 2. UNLOCK 2.1 WRITE IMEI (PHONE MUST BE ON AND KG800 CABLE MUST BE USED) - THIS STEP NOT NEEDED 3. WRITE FLASH WITH ' FULL ERASE BEFORE CHECKED' (ALL ABOVE WITHOUT POWERING PHONE ON AND AT THE END YOU WILL HAVE A LOCKED PHONE) SECOND STEP: 1. UNLOCK 2. POWER ON, POWER OFF PHONE 3. WRITE FLASH WITH ' FULL ERASE BEFORE CHECKED' Q: HOW TO FIX NO NETWORK PROBLEM IN VODAFONE 225 ARABIC FW (ArFr) ? 1. 'SECURITY REBUILD' using VDF225-P108A2B06-Tu-TU02_FW.bin 2. READ EEPROM 3. 'SECURITY REBUILD' using VDF225-P108A2B06-ArFr-EG04_FW.bin 4. WRITE EERPOM you read at (2.) Support Section : Furious Gold - Support Tutorials : Furious-Gold Online Tutorials & FAQ Cables list and details please check Bling Bling users : http://www.furious-gold.com/packing_list.pdf Br |
F.A.Q.-Frequently Asked Questions-Read before post [16 August 2011] Updated | universalbox | Universalbox | 14 | 08-16-2011 15:38 |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions. READ BEFORE POSTIING | ghosthacker | SAGEM JTAG UNLOCKER | 0 | 08-07-2009 16:46 |
F.A.Q.'s - are here. Read before ask! | GSMtricks | PadFinder box | 0 | 03-24-2008 16:56 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
