09-25-2018, 01:47 | #1 (permalink) |
Freak Poster Join Date: Jun 2017
Member: 2730595 Status: Offline Thanks Meter: 13 | F320 flashing problem i got 1 phone zte f320 for unlocking ,but that phone unlock counter was blocked i tryed for unlocking its error , after that i have done flashing but its stoped half flashing,, below id log pls give me a solution Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem215.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM43]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 00C8:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: NONE SW IMEI[1]: NONE SW IMEI[2]: NONE SW IMEI[3]: NONE SIMLOCK FLAG: OFF FIXED NV BASE: 40040000 Re-programming; Doing the setup; Done; ERROR: Data send ! Data programmed; Done; Remove battery and cable; Log file saved to: LOG_25_09_2018_13_42_44.txt Time needed - 00:01:55 |
