01-14-2010, 09:00 | #1 (permalink) |
Major Poster Join Date: Dec 2008
Member: 920356 Status: Offline Thanks Meter: 3 | fg 2010 edition box problem I bought brand new Furious Gold Box I follow this instruction and install in freshly formatted/installed OS pc Q: What OS (operating system) are your softwares compatible ? A: Windows XP/2K/Vista. Q: I just got my box and i would like to install drivers. What to do ? A: There are two drivers to install on first use. First get FG_FTDIDRIVER.rar from support, extract in one folder and after connect box to usb cable. In this moment windows will request this driver and just point him the correct directory. After get from support FG_SMARTCARDDRIVER.zip, extract in one fodler, right click on ini file and choose install. End these operations by resetting pc. Q: What is the next step after installing drivers ? A: download latest maintainance tool extraxt on new folder, run the maintenance exe tick format & execute selected operation to double size the dongle volume after finish tick generate licence then click on execute selected operation, after the licence has been generated click on go to support area, you'll be logged in automaticly to support area go to download area >> setup, download the latest installer and make sure to download the latest beta modules, install furious installer and exract beta modules on furious installer folder make sure to put the generated key inside the installer folder. Here comes the problem run the maintenance software, it worked fg box detected exit the sofware then run again no card-reader(s) found, WHY? removed fg box from cable then reconnect box after several minutes, run software it work again exit software then run again, no card-reader(s) found WHY? Any solution for this? Remember i install the software in a newly format pc, so probably no conflict in driver I also use the latest maintenance software from support |
01-14-2010, 11:03 | #3 (permalink) |
Member: 920356 Status: Offline Thanks Meter: 3 | kindly check the screen shot of my device manager at the link below i can't upload it in other imagehosting my internet connection here is tooooooo slow http://www.mypicx.com/01142010/my_device_manager/ |
01-14-2010, 13:21 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | i had the same problem that it could not even read card.if you have the gut like me open your furious and check if the small dongle is sitting properly.just unplug and replug that dongle'it will definitely work. |
01-15-2010, 08:36 | #13 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | It can be that the dongle it's half unplugged. Contact your reseller if he allow you to open box and recheck dongle connection Regards Furious Support |
01-15-2010, 08:59 | #14 (permalink) | |
Member: 920356 Status: Offline Thanks Meter: 3 | Quote:
mine is 2010 edition, no dongle 'coz its "dongle built-in pcb" according to my reseller | |
@@@..Hot solution exe.by mobi_soft--2010 Edition...@@@ | mobi_soft | Nokia Hardware & Hardware Repair | 27 | 04-04-2010 13:38 |
rap3gv3_2nd.fg RAP3Gv3_algo.fg - possible edit this loaders ? | *Diablo* | GSM Programming & Reverse Engineering | 5 | 02-14-2010 23:18 |
Nokia Lcd Finder Version-3 [Christmas and New Year Gift]by Mehmood Riaz -2010 edition | izhanji | Nokia Hardware & Hardware Repair | 0 | 12-24-2009 12:00 |
fg box problem | mobilshopprimi | FuriousGold | 0 | 11-27-2008 16:38 |
