05-03-2016, 12:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UK NETWORK SOURCE
Member: 908175 Status: Offline Thanks Meter: 314 | fg team plz help to unlock vodafone smart speed 6 [SOLVED] |
05-03-2016, 12:15 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Drivers are included in each and every OTSmart archive and are the same as for any of the supported models from this module Br |
05-03-2016, 12:19 | #3 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | sir i have sorted that but now i am having this isu Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM245)) Preparing to start flash mode; Preparing to open COM245 Connecting; Downloading DA; Initializing; Rid: 6b2e6537e151976da404c72a59627dff Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem210.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) ERROR: Change DA USB VCOM port value to a number between 0 and 255; ERROR: BOOT_PHONE; |
05-03-2016, 12:22 | #4 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | I think that you can read "Change DA USB VCOM port value to a number between 0 and 255;" Go device manager when this error occur and do what said Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
05-03-2016, 12:30 | #6 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | it is done sir thanks for ur help Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM245)) Preparing to start flash mode; Preparing to open COM245 Connecting; Downloading DA; Initializing; Rid: 6b2e6537e151976da404c72a59627dff Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem210.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM17; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0xD9B90042 0x8BA2CC9B [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-361116-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2AVDGB2 USRDATA INFO: 0x99000000 SIZE: 0x39880000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 7426307207385109 enabled: yes tries: 10 code_cat_ns: 7188974033395090 enabled: no tries: 10 code_cat_sp: 3212592902807888 enabled: no tries: 10 code_cat_c: 7591844216215120 enabled: no tries: 10 code_cat_sim: 5082082243683814 enabled: no tries: 10 code_cat_ns_sp: 5082082243683814 enabled: no tries: 5 code_cat_sim_c: 5082082243683814 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_3_05_2016_12_29_1 |
