01-02-2010, 04:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 44
Member: 693632 Status: Offline Thanks Meter: 14 | flash kp500 not support! |
01-02-2010, 06:12 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Many times posted b4..FG doesnt support KP500 flash..search the forum for get free flasher and flash file.. here its is http://forum.gsmhosting.com/vbb/show...42#post5208942 |
01-02-2010, 06:15 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
1.) BACKUP - First off all you should make a backup of your phone files (contacts, messages ...) because after flashing, all the files saved on the phone will be erased. I recommend that you use LG PC SuiteII. - Dont forget to unplug your phone. 2.)DOWNLOAD GSMULTI AND FIRMWARE FIRMWARE LG KP500 KP500AT-00-V10n-DEC-17-2008 (v10N) NEW! http://www.filefactory.com/file/a03f...N_Firmware_rar FLASHER LG - MultiGSM ver 3.0 + kp500 .dll file http://www.filefactory.com/file/a03g...SMULTI_V30_rar 3.)INSTALL THE SOFTWARE AND DRIVERS - DRIVERS WORKS ONLY ON XP WINDOWS (Don't connect your phone on computer yet) Downloaded files should be un-ziped (I unziped them in one folder which i made it on desktop) You got next files: program - SETUP_GSMULTI_V30 - KP500_081002.dll firmware - KP500AT-00-V10n-CIS-XXX-DEC-17-2008 - KP500AT-00-V10n-CIS-XXX-DEC-17-2008.bin.mbn 3.1.) Install GSMULTI (SETUP_GSMULTI_V30). The icon will shows on your desktop otherwise the program install on C disk, folder GSMULTI - start GSMULTI - select: Settings/Configuration put .dll file and firmware file in and choose USB then click OK and close program 3.2.)Install DRIVERS (INFINEON and TI_NEPTUNE) Drivers to be found in install folder of GSMMULTI program. My path is C:\GSMULTI\UsbDrivers First install INFINEON - Second TI_NEPTUNE 4.) PREPARE AND CONNECT YOUR PHONE - Now u take a phone (shut it down) and remove, BATTERY, SIM CARD and MEMORY CARD then - conect it with your USB cable to computer (I suggest that u connect only in one USB port on computer) - wait about one minute that comuputer recognize new device 5.) USBMap PROGRAM - Run program USBMap_V01 (which can be found in C:\GSMULTI) - Select INFINEON and then click MAPPING START WAIT (about one minute) that USBMAP will find USB port where is the phone connected - When the port will be found click on (select it) and press SAVE&EXIT 6.)MAIN PART - FLASHING - Run GSMULTI program (shourtcut is in your desktop) - Check if settings/configuration are the same like we set it before (otherwise look step 3.1.) Now its everything ready to start flashing - Check MODEL and SW VERSION and if that is correct just click START and wait until the program finished And voila, here we have a new firmware version i got this inofrmation from shauneco Stick Out Tongue | |
Flash nexian g922, flash device not supported | fcs | SpiderMan | 3 | 04-28-2010 16:20 |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
kp500 not supported model [Solved] | uzmantel | Z3X-Team Products | 4 | 12-31-2009 11:58 |
Flash type not supported | .::AkhavanGSM::. | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-08-2002 08:58 |
