08-07-2019, 19:44 | #1 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1507732 Status: Offline Thanks Meter: 36 | MRD-LX1F Huawei Y6 2019 IMEI Repair Done Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port_V1632 (COM67)) Preparing to start flash mode; Preparing to open COM67 Connecting; Downloading DA; Initializing; Rid: b372ffb30bf3cba8720a1af915520479 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x2F200142 0x3716A0D2 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Searching data; Checking data; Contents saved to : K:\Download\HUAWEI MRD-LX1_IMEI_E2962A69_14AFC19F_b372ffb30bf3cba8720a1af 915520479_7_08_2019_23_39_26.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM492)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; IMEI repaired; Remove battery and cable; Time needed - 00:01:04 |
The Following 8 Users Say Thank You to /\/\@ster For This Useful Post: |
08-15-2019, 07:15 | #10 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
One small hint regarding new MTK Huawei imei repair that we added. If you want to have the imei change permanent then after changing the imei using OTSmart use Resurrector and update the phone firmware in upgrade mode ! Once you do this the imei wont reset back to default as before at least for y5 this method works fine Job done Sent from my iPhone using Tapatalk Pro | |
The Following 4 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
08-16-2019, 20:23 | #13 (permalink) |
Freak Poster Join Date: Aug 2011 Location: pretoria
Member: 1636627 Status: Offline Thanks Meter: 24 | i changed imei but not changed inside. i tried with latest version also 3492. i even flashed with file from support but same. operation done but imei not changed inside phone |
